Your right there Matt. Iv adjusted the idle @ 14.7:1 and reset back to closed loop with fair results. I am how ever pinging at around 3600--up. Have chased it out all the way up to 5600 but is a real pr1ck to do on your own.. I'm due for the dyno this Saturday. Maybe easier than on the road.
  • Replies 61
I have had hunting and it has always been caused by lean mixtures. ie 16:1 being the center instead of 14.7:1.
I dont know what my mixture are, but to smooth my idle out I just kept pulling fuel and adding timing - the richer I go, the more prone it is to hunt?
what map settings do you have for ign and inj in the first 5x5 cells? if you have time to check them:)
Can you use the O2 sensor (or some other method) to read AFR's? If so, what voltage = what AFR?
I wouldn't mind doing some road tuning, but have no idea what my AFR's are (guessing
The first five cells I try to keep very similar(Ign)( no more than 18degrees from 15). I found with my 264 cams the richer i go the more stable idle is. The car wants soo much more air to idle that the idle up screw is all the way out and I had to re-adjust my throttle stop screw aswell.
sh1t, I am running between 34 and 36 degrees:) and fuel is between 0.988 and 1.004. I have found any more fuel and she doesnt like it - still a bit rich though.
got the AAC valve all the way out too, but found by setting the TPS to 0.60V it was happy, didnt mess with the throttle stop.
Jeeze- heaps of timing, I'll have to see what mine likes. I only started playing with my idle last night. I was refering to my standard cams in regards to hunting.I drove to work this morning and it sat on 2000rpm all the way... not cool lol. Love the sound at idle with the cams, it sounds so tuff. you can feel each individual explosion in your chest.
Temp correction AFAIK, corrects amount of fuel being delivered - similar to a choke function, so the car will idle on warm up.
If you find it idling better on 1.15, perhaps you need to adjust the maps? Raises an interesting point though, why does the power fc allow correction at full operating temp?
  • 1 month later...
First see if you are running closed loop or not, in ETC, under FUNCTION SELECT. It can be enabled and disabled in the same way knock warning is.
Is it best to leave it on or off for normal driving?
If you car is tuned at low rpm for cruzing and saving fuel the turn it off. If you have a normal tune then you should leave closed loop on so that the computer can make fuel corrections on the fly and save you fuel. If your oxygen sensor is old and dirty then closed loop will screw your fuel consumption...
I've read some people have probs with the PFC causing hunting at idle and mine is doing it.My AAC valve worked fine before all of the mods but now it sometimes hunts and stalls if i give it a rev or slowing down,Same if you have a atmo venting BOV.
Also if a back off sometimes it's like someones blipping the throttle WTF is with that?
just a note to expand on Steves detailed post on tuning for economy......when doing the cruise set up at 50kpm, 80kpm & 100kpm at light throttle on a level piece of road the ignition can by set fairly high. I have my PFC at about 38 degrees at these points. This also enables you to run a nice lean mixture which further increases economy. Be careful to pull this timing out quickly though as load increases. The base maps will do this anyway but I'm just explaining why. The PFC pulls out 5degrees timing, hard coded, when you plant it anyway to help guard against detonation, this is non adjustable as for your own good anyway.
Also when the car is coming on to boost is when you start to aim for 12 to 11 :1 AFR on the wideband. To be more precise when your boost meter reads "0" (atmospheric), say on a medium hill holding a constant speed, you should aim for 13:1 ish. My GTR base map had 14.3:1 at this point and was a slug coming on to boost as a result!
Once boost is heading towards4 to 6 PSI aiming for 12.3 to 12.5 :1 is appropriate.
Once boost is up around 10 PSI you would want at least 12.2 to 12 :1 ....anything over 14 PSI 11.8 up to 11:1 is a must!
These are quidelines for the tune it yourself person, to get the best out your car a dyno tune is a must as differences of 0.2 of a AFR can make a big difference to torque and this can only be seen on a dyno graph. But as you can see the AFR increases gradually with boost until you reach the "best" figure for your car which could be anywhere from 12:1 (fairly lean at boost ) to 11:1 (fairly rich at boost but nice and safe)
hope this helps
Mike
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
