Hi,
I feel very stupid as heading states I hooked up fuel lines wrong way round. Just put my rb26 in my car and connected them up not thinking just so fuel didnt drip everywhere and to get them out of the way.
I hooked up wiring and fuel pump and starter, I just wanted to turn it over after rebuild, turned key to accessory and fuel pump started. meanwhile i could hear a strange pressure building noise and quickly switched it off.
very soon after i realised that fuel pressure had built and obviously couldnt get past the fuel reg and fuel passed through the injectors into the cylinders.
Q 1. are my injectors going to be okay after that sort of abuse.?
Q 2. is my fuel reg going to be okay?
Q 3. will this effect run in and the hone job on the bores or the rings themselves? (Fuel was pushed out of cylindars within half an hour.)
Q 4. Will I not know any of the above until I test each thing.
Thanks
Taylor.
I don't understand, I hooked mine up the wrong way as well once and fuel just didn't get past the reg, so how has it got into your cylinders ?
fuel shouldn't get past the reg the wrong way and pump should turn off once pressurized
I assume it pressurised the injectors so much they leaked out the tip. fuel got into the cylinders through the injector tip. fuel pump didnt switch off once pressurised it just kept pumping and filled the cylinders in seconds
on an rb26 the rails pressure reg is on the front of the rail itself before the injectors. the lines were reversed so the fuel went to all of the injectors first and stopped at the reg at the end and i assume couldnt get past the reg
Reg is definitely on return side cause it needs to regulate pressure in the rail..
so sounds like it is hooked up the right way..
So either your pump isn't switching itself off once pressurized, have your rewired it lately?
Or your injectors are stuck open for some reason..
maybe your injectors are getting voltage I dont know why this would happen
I had 90psi fuel pressure on mine and it wasn't enough to push injectors open, then again my pump would switch off..
Fuel can't get past the reg and even if it does you won't have much pressure in the rail because there is nothing to stop it running back to the tank.
The reg restricts flow back to the thank to increase pressure in the rail.
Your injectors, reg and engine will be fine.
If you're really scared and want to be sure pull the spark plugs out and crank the engine over with the cam angle sensor disconnected to clear out any fuel in the bores.
Id say more then getting the line's the wrong way you have leaking injector seals? Or the reg jammed shut over pressurising the rail causing fuel to leak past the injectors?
Everything would now have been washed of any oil on its surface. Id drain everything, leak everything open for a few days to let any fuel evaporate out then refill with oil, then crank it by hand for a while?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
