Hey guys and girls....
Have been tossing up for awhile weather to get a r32 GTR or 34 GTR....
I like white in both cars and ive seen some hot white 34s going around but not many 32s?
Can someone post some pics of HOT white R32GTRs
Also in the 32s what little add on body wise is there without going stupid like bolt on flares etc? Just things to set it apart from others?
Any help would be great
https://www.sau.com.au/forums/topic/396321-r32-gtr/
Cheers guys!
Im still unsure.
I just dont think the 32 GTR looks different enough from the GTST without changing kits etc :/
Those canards on the 32s, where do you get them from?
I'd just go a Nismo body kit:
Front intercooler vents on front bar
Bonnet Lip Spoiler
Boot Lip Spoiler
Side skirts with rear quarter panel spats
Trust Rear Pods (In picture)
Personally I don't like the Bonnet Lip Spoiler.
R32 GTR's have streamline looks, so they look better with a nice subtle kit
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6296299
Google images broken on your computer?
maybe look in the yellow pages for pc repairs in your area? the quicker you get it fixed, the quicker you can google search for pics, and stop getting everyone else to do it for you...
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6299355
Thanks guys! cheers for the build thread!!!!
Argh still cant decide 32 or 34..... seems like if i get a 32 everytime i see a 34 go past ill be like s**t should have got one of them... BUT if i get the 32 i can chuck a bit of cash on mods to it... where as i cant for the 34 :/!!!!
https://www.sau.com.au/forums/topic/396321-r32-gtr/#findComment-6300152
