Hey Guys,
Just finished the tune and the car made 250rwkw
On the way home in 4th and 5th as soon as it comes onto boost it slips.
Pretty dangerous when trying to overtake etc.
Just wondering what you would recommend for around the $500 mark? or am I dreaming for a $500 - 250kw clutch
https://www.sau.com.au/forums/topic/396332-time-for-a-new-clutch/
a good clutch isent cheap, and a cheap clutch isent good. Id put 2k aside, I've been looking around aswell, nismo suppercopper mix seems up there with the best for off shelf, custom jim berry or direct clutch, either way you won't get anything for 500
Are you installing the clutch yourself kasko? If not, I'd budget about 550-600 for labour ontop if you save the oil.
You could also look at the single plate nismo copper mix from perfect run, comes with everything and new flywheel I believe...
Edited by Mitcho_7
I had mine 'made' by K B Clutch Engineering in Sydney, the clutch is good quality and well made, though I ordered a 5 puck, he ran out of 5's and sent me a 6 without telling me, and thought that was on ok thing to do. Apart from that, it's a good service. For around the $400 mark you will get an exedy 4-5-6 puck sprung brass button centre with ceramic pads and then he will make you a custom pressure plate depending on your power/torque levels. Mine is rated at 1300kg clamp pressure / 240kw / 440nm / 6400rpm and cost $400. Seems like the way to go, you would probably get a similar clutch with a higher clamp load. I just finished putting mine in this afternoon and it feels almost like a normal stock clutch with a bit shorter travel, it's very easy.
How is your tailshaft? Good time to change the uni's.
Thanks for the info guys
If I have to spend the money I will but the build has already pushed my bank account.
Sweefu sounds like a good clutch I wonder how well it will hold up.
I would go the nismo but it's nearly 2k for it.
Will either install myself or get Shane to do it at work for cheap as labour.
single plate nismo is about 1200, it's the twin plates that are 2k+
If you're only wanting something to hold a bit more than you have now I reckon you would be fine with an npc clutch or something similar mentioned above. I only got a Jim berry because I am plannIng for the future as well as the present.
Edited by Mitcho_7
if you get a chance get the nismo coppermix. Got one in mine @250kw n it is the ducks nuts. So well sprung n easy to use. U can take off softly like a stock clutch or have heaps of clutch feel+grip on a hard launch to get the best take off.
I murder peeps with buttton clutches all the time cos they either bog down or wheelspin. N they have to live with that heavy on-off shit.
I love mine so much it makes me sleep easier..
Contact them and double check to make sure. Might also be worth asking if they are willing to underquote the price of the clutch on the invoice to keep it under $1000 inc post so you don't risk getting hit with import duty and gst...
EDIT: Just looked on the nismo website and it says for the r33 gtst you will need to purchase a Nissan genuine engine plate (Part no: 30411-05u01) and exchange with the existing part.
http://www.nismo.co.jp/en/products/competition/clutch/pdf/clutch03.pdf
I think that is the engine backing plate the from the 33 gtr and 33gts4 maybe?
Edited by Mitcho_7
Just make sure you have a new spigot bush and release bearing.. Can't remember the proper name but I call it a release bearing. How much is the Nismo? The clutch I mentioned would be able to be made to hold your power no worries, I know someone running a similar clutch with a higher clamp load with 315kw / 700nm (perhaps he will post up in here) .. If you needed to save some cash, that could be a good way to go.
So all up sweefu it set you back $800?
The nismo from what I could find was around the $1200 mark
If you're not chasing much more power Kasko, I recommend the Exedy cushion button that I'm running at the moment. We have the same turbo / similar power and it's not slipping for me. This clutch has been in my car for years, seen hundreds of hard launches and lots of slippage with daily driving...she's still holding strong after the power upgrade. It is a very friendly clutch, not harsh on take off like a normal button clutch, but it puts down the power if you want it to. Time will tell, but I'm certain others have run it at this power level without issue. Otherwise, there is always the Exedy HHHDB, which many people with 300rwkw+ have run without issue.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
