  • Replies 66
Posted Images
ok, so i plugged the nistuned z32 ecu back in and recorded the dash with aircon on and aircon off. I also recorded the standard ecu with aircon on and aircon off.
This is with the standard ecu plugged in
This is with the z32 ecu plugged in (note the exhaust temp lamp)
The idle with the z32 ecu in is higher and it was recorded second after i had already had the car idling for a minute or 2 on the standard ecu. With the air con on with the z32, the car doesnt sound like it does with the standard ecu.
I took the car for a spin with the z32 ecu plugged in and revved it out to about 5500rpm in second and third and it didnt stutter or go into limp mode at all. My consult display also shows no fault codes with the z32 ecu plugged in.
We put the Series 2 33 changes in based on information from another customer when they installed in their vehicle. The main problem is I dont have a S2 wiring diagram/pinout to compare against. Yeah I was thinking series 1.5 also
Anyway been going through their emails back from Aug 2010 and found this page (attached)
So pin 32 is the Exhaust Over Temp lamp on the S2 RB25. It connects to the Check Engine Light output on the Z32 ECU. So effectively your exhaust temp light is the check engine light output from the Z32 ECU now
Question now is what is the Check Engine Light output on the S2 RB25 pinout? I'll contact the customer who bought the NZ workshop manual and find out
Edited by darkhalf
In the video with the z32 plugged in and the a/c on the idle doesnt seem to go up a bit like the name fast idle control device dictates it should. Then, when its turned off it jumps up abit then settles again, so i dont know if the FICD is actually working or not.
On the pinout diagram for the z32 I cant even see exhaust temp lamp so I guess it doesnt use one and which ever pin is the r33 series 2 exhaust temp lamp on my loom is plugged in to something it perhaps shouldnt be on the z32 ecu and its turning the lamp on.
EDIT: Just read Matt from nistunes post above. Let me know when you hear back from them Matt.
Edited by Mitcho_7
I've got those diagrams above (link on second one broken)
www.gweeds.net/nismodore/rb25diagram.jpg
The ECU pinout from the same site has the Series 1 mappings for both lights
Series 1 uses
Pin 32 = Check engine light
Pin 33 = Exhaust temp light
which ever pin is the r33 series 2 exhaust temp lamp on my loom is plugged into something it shouldnt be on the z32 ecu and its turning the lamp on
Series 2 uses
Pin 32 = Exhaust temp light
Pin ?? = check engine light
Z32 ECU has no exhaust temp light output. Its Pin 32 output is 'check engine light' as previously posted
Series 1 uses
Series 2 uses
So essentially the exhaust temp light with the z32 ecu installed how it is at the moment is actually the check engine light?
If that is the case and the check engine light is now through the cat light disconnect the tps and check it to see if it's using the standard 1.
And if it was using the cat light why is it throwing the light with no codes, I reckon pull the plug for the cat sensor first and see where you stand.
Edited by Stevoss
I have no idea how to do this and dont really want to be pulling out wires etc as the car is also my daily and I will need it next week
You raise a good point about why the lights on with no codes, im only going off of what my ecu consult display from ecutalk.com says when I go into faults.
The good news is its easy and very quick to connect and disconnect the tps, you just look at the top of the motor and where the throttle butterfly is that moves when you push the accelerator peddle it has a small black box on the other side, you push in the little tab on the plug and pull the back half to release, it will log this as the fault code and display the dash light, you can clear that with consult after.
You are brave man ..! Or was the ECU tuned?
Also more on the topic, what is the colour of your Crank Angle Sensor?
(black housing, or metal?)
Edited by Torques
dont know what you mean? the only way i know of it working is the z32 ecu with the nistune daughter board running the standard ecr33 rb25det tune.
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
