what do volunteers get them selfes into?
Straight away you become a rockstar in your SAU Officials vest.
We need volunteers to help with starting off the cars, timing and keeping a eye on the cars on the track.
We hook ya up with drinks and pay for your lunch.
And if you come out with us on saturday night you may find a drink or 2 heading your way.
So if you could help out that would be fantastic.
  • Replies 193
oh wow that sounds like fun but ive never done anything like that before what if i make a mistake or not sure of something? :wacko:
If timing is not your thing i can find something easy like letting the cars in and out of the starting or finishing gates.
easy as mate. Would not put you anywhere you were not cunfortable with.
And if your coming up to watch i can get you right up close to the action.
Its also 1 of the best way to meet other club members.
Good stuff. I'm posting myself on the Mini Wang this time, if there's two spots you are more than welcome to join me and I'll keep you company/show you what to do. Or you might want to volunteer on the skidpan instead as you'll get to be around more people and cars. Either way you'll have a ball.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
