Like Boostmeister says - use the layer mask.
Also use a soft brush. If the OEM ones aren't soft enough, you can 'tweak' them by using the side option menu from the brush-size dropdown (in PS 7)
Jamezilla, good point.
Hiroshima Screamer, if you have problems, send me the pics and I will do it for you [email protected]
PVA, you can do in in PS but its not just a insert and done type of program unlike the software that comes with cannon digi cams "Photostich".
Here's an example of photo joining in PS.
This is what 3 seperate photo's look like when joined, there was actually a fair bit of work in doing this. For those who don't know where it was taken....This is the view from 10 meters out in the water at 6am on a Sunday morning at Surfers Paradise. You have about ten minutes to take the shots you want before it gets too bright.
Black and white is easy to do but there is B&W and there is B&W, I personally like "Black" not grey so you have to tweak the pic a bit. This is done in curves to a good effect.
First though just open a colour bit the go image>mode>greyscale to change it to black and white, just remember that you will not have all effect options available to you to use so mod the pic first THEN GO B&W
Just did it quickly, it all comes down to the images you start with. Make sure they are high res and try and take as many as possible, this is not always the case, it will depend on your camera.
Some cameras expose the shot well while others can make the sky totally different colours, this is when it is hard to blend....sometime I have to almost totally recreate the entire sky
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
