This guy, Brendan, super awesome service. Took my call after hours and sorted payment within the hour. Had it posted the next day! Can't speak highly enough of the service and I'm definitely going to keep coming back. Good work man
It's all part of the service :yes:
Don't forget to like PEC on Facebook and let's keep in touch.
  • Replies 191
After a price and availability on a set of 6 x ID 1000 to suit an R32 GTR to fit into standard rail.
Will this be a plug and play type of injector?
Are they genuine ID injectors?
After a price and availability on a set of 6 x ID 1000 to suit an R32 GTR to fit into standard rail. Will this be a plug and play type of injector? Are they genuine ID injectors?
Hey,
ID use BOSCH EV14 injectors which is what we offer as well, they are just flow matched by a different company also based in the USA.
Injectors won't be a direct drop in; some modifications would be required.
Price for 6x 1000cc injectors, 11mm extensions (GTR) and USCAR plug's would be $640 incl. delivery.
- Brendan
Hey,
- Brendan
Same price for a bnr34? is this all that is required to fit/run these injectors? apart from the usual tune etc of course.
Yes same price, same set-up.
Nothing else will be required in terms of fittings ect, however it would need to be fitted by an experienced workshop as the injectors are universal.
Cheers,
Brendan
(VM)
Can i have a price on the Bosch 1000ccs and 2000ccs to suit rb25 plz
Hey!
Including all required extensions and plugs here is what I can do:
Set of 6x 1000cc BOSCH EV14's - $640 incl. Express delivery
Set of 6x 2200cc BOSCH Short's - $790 incl. Express delivery
Let me know what you thing,
Brendan
(VM)
good price! probs easier to get the 2000cc ones now just incase i go a bigger set up....
How is drivablitly and tuning ease going much bigger then needed?
Yo!
Yeah the in terms of tuning the EV14's from BOSCH are easier to work with then the 2000cc ones. In terms of drivability the 2000cc cater for serious engines builds.
Hey bud in interested in some sode feed inj to suit an rb25 prefferavly sard 550 or 800cc injectors how much for a set of 6. Contact is +61 497 075 260 easier to get me that way prefferably in a message cheers
Josh
Josh
Hey Josh!
SMS just sent.
  • 1 month later...
Hey!
Brendan
(VM)
Yo!
Got an R34 GTT and bought some fuel injector clinic 1000cc EV14 from you and was thinking of going bigger. You have said you have 2200 injectors (bosch shorts) but they are not as easy to work with. Surely the IDs also come in 2000cc don't they?
I am looking here http://www.injectordynamics.com/injectors.html
and they list 1300cc as well as 2000cc. Now I realise the ones you stock are not injector dynamics but if bosch make the EV14 injectors 1300cc and 2000cc would fuel injector clinic not be able to flow match these in the same way or is it just not a size that they do?
Please let me know some options.
Thanks
Thanks
Hey,
At present we don't have anything between 1000cc and 2200cc which are the shorts.
I'll have a look into this for you now and see what I can do.
- Brendan
  • 3 weeks later...
any sard top feed 770ccs?
Hi,
Nothing from Sard at present, we are getting a batch in within the next 2 weeks though!
- Brendan
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
