Hey guys,
having an issue with my s15 (sr20det).. no idea where to start :\ similar issues seen with skylines so yeah..
Car is choking while cruising, feels like its going to stall eventually. Was fine all week until Thurs night and then got progressively worse.
Seems worse at 60km/hr or low speed than 80km/hr. If I thrash it, it seems ok..? Maybe?
Maybe a related issue that has been going on for a few weeks is when braking to red light, sometimes the revs drop to about 200, cpl of times it has actually stalled on the freeway in heavy traffic/freeway carpark.
Have looked at every hose (I think), cannot see a vacuum hose off anywhere..
I thought AFM for the choking issue but swapped it yesterday with a friends and no difference.
Plugs were done a few months ago, pulled them out, they seem ok, asked 2 ppl for advice they said they look ok as well..
What else to check?
Another friend said o2 sensor but I think my fuel economy would be shit if it was that.
No idea when the fuel filter was last done as I haven't had this car long, would that be an issue?
Im thinking ignition or fuel at this point but not sure..
Thanks for any help :(
Kaz
https://www.sau.com.au/forums/topic/397264-car-choking-while-cruising/
hmm ok the only hoses i havent checked is the FMIC joiners at the bottom.. will check today
I'm in westside melb..
hmm ok well im going to Autobarn to get fuel filter soon...
Gawd at this point it has not been narrowed down, I'm only getting more suggestions lol.. thats helpful but not, at the same time lol :(
I would try fuel filter first also check pump flow a mechanic shop should be able to do this one other thing could be the cat could be blocked. Might be worth putting it on the dyno and removing the exhaust and checking the rest
try a new fuel filter.
is there any kind of EGR (exhaust gas return) on the car? it may be that it needs to be cleaned out. i know that is a common issue with the natro sr20's.
also try unplugging the o2 sensor and seeing what that does.
finally, is the car auto or manual?
changed fuel filter today.. noticeable improvement in driving tonight but not sure if it's fixed it.. will test more tomorrow when going to work.. I suspect not tho it seemed to start faltering a little bit..
EGR.. nfi.
hmm cat blocked.. thats a possibility.. fuuuu so many things to check :(
need to borrow consult and see what it says.. tho from prev experience (180/r32) it usually has no faults lol, so may prove worthless..
did you clean the POD filter recently? i used a k&N recharge kit on mine once and applied to much oil which in turn stufed my MAF sensor give it a good clean with crc MAF cleaner and see how it goes i took it to 5 different mechanics wasted money on CAS coils Ignitor fuel pump then to find it was the MAF
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
