  • Replies 69
Posted Images
3000 RPM = 85 HP
3500 RPM = 120 HP
4000 RPM = 160 HP
4500 RPM = 240 HP
5000 RPM = 415 ish HP
5500 RPM = 470 ish HP
6000 RPM = 545 HP
6500 RPM = 610 HP
7000 RPM = 660 HP
7500 RPM = 700 HP
7900 RPM or so = 733 HP
* Going off the brown line
240hp at 4500rpm.....wouldn't want to be taking this thing through many tight twisty roads or traffic. It would feel like a sling shot when it comes on though no doubt. The real shocker is 3000rpm, my stock 10 year old commodore makes more than that at 3000rpm, so just cruising around town this GTR at least in my case would be way too laggy.
Sure the final number is great, about 542rwkw, but for anything other than drag racing, more area under the curve is needed.
Area under the curve doesn't impress most people though compared to a big number, so not a lot of people care which is a shame
Rhe commodore has another 1000cc capacity though
No 2.8l low compression motor that is designed to rev hard is going to be exciting at 3000rpm. Especially when it has big cams etc
Yeah fair enough but also it's a POS and has no turbo.
Anyway, I'm not trying to put this result down or anything, just IMO it doesn't seem to be a very usable car around town. Who knows, the owner may just love revving the shit out of it and good on him cause above 5500rpm it would be moving bigtime and would leave my GTR for dead in a straight line.
FYI Paul makes 201rwhp at 3000rpm, 270 cams, 2.8 etc which is close enough to 2.3 times the power. So yeah has certainly be done.
True!
My 33 made peak torque at 3000rpm can't remember the figure power wise though wouldve been around the 110-120kw range, was a straight line upto 6500rpm :D
Much nicer than the 1j lol
I guess it could also be that if a fast ramp rate was used it would push the curve to the right and make it look laggier than what it is
If you were 'cruising around town' then you wouldn't need to accelerate...so 4th gear at 70KM/H would be fine with low power. And if you did want to accelerate, then simply put it into 2nd (and right into its power band).
Although, I would have to agree that any twisties and it would make a much bigger difference. It's horses for courses.
And yes, zebra, a dyno run may not accurately reflect on-road performance for various reasons - they are really more of a tuning tool.
haha my gtr makes about 65hp at 3000rpm an bout 290hp 5000rpm an only makes 420hp atw 7800rpm pretty sure my car didnt make 100hp at 3000rpm even stocklol if
i wanted low down grunt i'd buy a falcon... but only reving to 6-6.5k? thats a bit gay lol
hmm stroking the engine is on the verge of cheating lol an if ur gunna stroke it why not go an rb30/26... then why not get a 3.2L stroker kit for it... or why not go one step bigger again an u got a 4l falcon engine lol or i did see a gtr with a gen III v8 under the hood with a cpl turbo's hanging off it lol each to their own. an yes in town i would swap for a stroked engine very quickly, as its rather hard to give it 60% a bit at the lights, its either a full on launch or 4wd diesels can beat me if i idle off lol an thats a little embarressing :blush:
You need to come for a drive with me Steveo :)
if you can't drive a car with a 3500RPM powerband you need to stick with your stock commie lol, plenty of fun to be had, just need to know how to change down gears.
you can't compare 3000rpm in a car which is limited at like 6500rpm, and is useless above about 5000, to a car that revs to 8000rpm and has torque to the limiter.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
