There are new ones on ebay for under $200 shipped just in case anyone is interested
link, found a few with many bids still rolling, and cheapest i found shipped was 245.
i would assume a new one would be a while off yet, they tend to make them last for a while.
  • 3 weeks later...
  • 3 weeks later...
Both the flatmate & I purchased one each for $195.
The main reason we bought them is due to our addiction to online drifting with GT5, however, we''ve found the G27 isn't very user friendly when it comes to the drifting aspect of the game but instead more towards the racing aspect. It may be due to the configuration/setup we're using but so far I'm regreting I ever made the purchase as I'm not a huge ps3 gamer & probably won't use the G27 once my GT5 phase wears out.
so if anyone knows a good drifting config/setup for GT5 with the G27... please post it!!!
Yeah I thought it sucked at first when drifting but you do get the hang of it, although the drift mode makes it too easy to slide, drifting in race mode is more fun :D
I paid $400+ for mine ages ago, these are crazy cheap!! The force feedback etc makes them great for gaming....
it just takes practice to drift with the G25/27 on GT5. and alot of throttle control.
the easiest way to learn how to drift in the game using the wheel is just running a normal race with whatever car you want to drift. or run practice mode if you dont want other cars around.
run the car you want to run, no traction control, ABS is up to you. and start to use a bit more power on the exit of the turns, i'm not talking about stabbing it to 100% throttle straight away. but a bit more than what you usually would. then once your comfortable with it, start putting more power on at half way through the turn, then at the start and finally before the turn even starts.
Edited by liger
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
