Hey fellow stagea owners,
Just need to clarify where about's the oil pressure sender location is on my rs four s stagea. Looking down at the oil filter there is a little spade piece that comes off to the side and i believe this is for a oil temperature gauge if I'am correct.
Used to own a R33 gts25t and the oil pressure sender replacement was just a screw in item to the block but i cannot seem to find anything which I could connect a oil pressure gauge to on my neo engine.
Has anyone got around to installing a aftermarket oil pressure gauge on their series 2 (rs four s) in particular as I'm getting around to installing one on my stagea soon.
Best regards Chris.
https://www.sau.com.au/forums/topic/397613-oil-pressure-gauge-rs-four-s/
Yes I currently have an extension T'd off the warning light. It runs up to the bulkhead where the sender unit is screwed in.
When I install my oil cooler I will have another 5 or 6 places to choose from. Sorry its an S1 but I'm sure its the same.
I've found 3 options when I did mine ( rs4s ) t the light sensor fitting, buy a different sandwich olate or do what i did and get an m12x1.25 - 1/8bsp adapter and screw the sensor in the temp sensor hole.
Could you please possibly link me with a few photos Steven? Where is this light sensor fitting also.
May be interested in purchasing a new sandwich plate but where could I buy one from.. Just want the most practical option not too concerned about money at this stage.
Edited by hks33
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
