Have ya tried a stock cas to fix the misfire?
Haven't tried anything Pete. I just haven't driven it. That's an easy test to do though. I believe it's a hot join in the coil pack loom as I have deleted the standard igniter and running an aftermarket one. Now with the moving around of that loom It might have buggered one connection. That will now be redone with a plug. On the dyno it's at exactly the same point, on the road it changes with load, gear and ambient temp. Fkn shit thing.
Love the build mate!!
Regarding the misfire, have you checked the coilpacks are getting a strong constant power? I had a shitty misfire once which was the constant power in the loom dropping due to a dirty/coroded loom plug.
Thanks mate. I haven't, no. The loom itself is no more than 5000 Kms old. It was all fine the night I popped the engine, now this BS.. Yavuz will sort it. :)
I have a great suggestion on custom plates for ur car...GR8WHT (as in great white shark)
That costs money. Haha.
Bit of a delay getting out there. Looks like Friday or Saturday at this stage.
Finally made it to UE yesterday. Woohoo!
A few little things going on like staging the fuel pumps under "X" RPM or Boost. (No needs to have two feed 044's buzzing away on the freeway heating fuel and pissing me off). Obviously the stupid missfire will be looked at and a tune with some decent boost and RPM. ATM its sitting at 380 rwkw at 19 psi with 7000 RPM being used. A bit of cam timing to be played with (not for outright power but the broadest area under the curve I can achieve). Might chuck a 30 PSI run in there to see how much these little snails can make.
A picture I took of the sperm whale a few weeks ago after I gave it a wash. Currently it has Nismo LM GT 4's in bronze borrowed from Joey's car.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
