chicken wing thing got me stumped , arm out the window ? Mate of mine just about lost his arm doing this in his VW 55 years ago , pissed :)
I thought it might be the same trannie , you blokes talked me into doing mine :)
They said my motor was finished and I have asked for a photo a couple of times, but nothing in 2 days, maybe bullshit , when they did anything they would send a photo without being asked , so ?
According to the motec datalogging, front diff damage was always done under brakes because the 4WD hadn't let go quick enough
Moral is, if doing hellies, don't stop :D
the good thing is Mick, this cannot happen to me because I do not know what hellies are, what are hellies , sounds like getting the front wheels in the air ?
Hope my Quaife is strong enough :/
Edited by Nismo 3.2ish
That was just to make up my mind what I wanted... And save for it. Lol
I know I know. 20 large ain't gonna just come overnight
I would still have wacked in a temp box in the meantime and enjoy driving the car
I had one. XKLABA gave me one to whack in. However, the car is sitting at my mates old mans workshop getting minor stuff like side skirts and front bar repainted. Unfortunately nothing happens there very fast (been there almost 12 months soon). It's been that long that I almost forget that I own the thing. All good... Will be back on the road soon enough.
Better get your mates Dad to get his finger out, should have your Box soon and driving before Xmas :)
If your foot is off the throttle and you are braking why would it cause a problem, is it because they were not really built to be a 4WD in the first place ?
I forget the specifics but generally when you jam the brakes on hard trunk g into a corner after a full noise stint and the 4WD is still loaded up the two forces going different ways quite effectively removes the front diff housing, I have seen this happen a couple of times :(
Is this only if you modify the trannie or with a standard one ?
Sounds like it would go, BANG! :(
I doubt it would ever happen to me as I will not be putting it under those conditions, but would the Quaife front diff make any difference , better , worse or just the same ?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
