I think Piggaz is pulling our leg.....
There's no way he'd pull the pin on this LOL
but then again...
'most people give up just before the finish line' :(
Not pulling anyone's leg mate.
If I put the new box in ill never pull it down. It won't be the last GTR I own, put it that way.
Return to stock, sell the car. All the goodies bolt right onto the later model.
Engine is up for sale if I get offered the right price.
  • Like 1
U can get it in red as I've seen a few around...then u can get RANGA plates!!! That would be fitting
Oh piss off, wog. You should get some lamb horns and cable tie them on the front of the ADM.
  • Like 1
Do like i said man, get 34 and do direct swapage, good shit onto 34, 34 shit on to 33, 33 with 34 shit is worth more then 33 with 33 shit
And dont start whinging about space, i am working on something ATM that will mean i will have the space needed and some
Get OS88, get it into 33 and enjoy till 34 rocks up then swapski
  • Like 1
And engine, box and few suspension arms ain't the end of the world.
That and I can sit on the coin for a while and wait for a car that I want comes up.
Who knows how long that will take.
just buy a an R35 already Paul
  • Like 1
If you do do a swap of the running gear to an R34, then for the love of god pay someone to do it so its not parked in a garage for 6 more months. Passion is lost when too much time passes by.
  • Like 1
As long as you own a GTR, you will be happy. I should have kept my air horns from my gemini back in the 90s...the chicks luved them.
Get a dato 1600 with your running gear, baby GTR - make sure it's red
Edited by Marko R1
Why keep stuffen around, piss the White Whale off and get an EVO, save you a fortune :)
Not all bad I will give you $7k for your OS88, this price is based on the fact that by the time you get it, it will be obsolete :/
Pete, no EVO's. As much as I hate to admit, they're a much faster car, but they do miss a little something that a big fat R has.
An OS 88 and and BIG straight 6 won't exactly fit either ;)
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
