Hey all,
I will be getting my P-plates next year, so my parents are helping (read: paying for 75% of) me buy a new car so I can stop driving my mum's Tiida everywhere (god I hate it, it's like it has no noise isolation in the cabin). I quite like the looks and practicality of the AR-X FOUR, but I have some questions about them:
  1. What are the maintenance costs like on a Series 2 AR-X FOUR?
  2. Do the Series 2 M35 Stageas have any known issues (e.g, weak components)?
  3. Are there any turbo/twin-turbo kits for the VQ35DE engine that will fit the Stag? (for after the P-plates, stupid nanny-state restrictions)
  4. is there anything I should be on the lookout for when looking at an AR-X Stag, aside from the usual checks?
  5. For a stock suspensioned AR-X, what wheel sizes/offsets would fit, and which bolt pattern/size do I need?
  • Replies 50
Posted Images
After doing a little more reading, I know that I'll need a PCD of 114.3mm on the wheels for them to fit correctly, but looking at the sizing for a set of Versus Turismo Spada Ottimo 18-inchers (http://www.rayswheels.co.jp/cgi-bin/cgi2/english/sizeGuide.cgi?modelName=OTTI_S), I need to know what specific inset/hub clearance I'll need. Also, for an 18" wheel, what tyre size would fill the guards on an AR-X nicely without looking horribly out-of-proportion (too low/high profile)
1. Depends if you work on it or pay someone to service it, and how you treat it.
2. No, think of a Series 2 V35 Skyline with a wagon body.
3. Bolt on? Not if AWD. You will need to modify a single turbo kit's piping. TT kits are not possible due to front driveshaft. RWD? Yes, same as V35/G35.
4. Like what? Unusually high water damage?
5. Feel free to use the search button for info regarding this and also for tyre/wheel calculators, You will need the rim width and offset.
1.What are the maintenance costs like on a Series 2 AR-X FOUR?
Not that different to other cars. Other than engine oil/filters brakes and tyres, there isn't that much to do. The initial cost of changing all the fluids in the car is high, as there is a lot to do, but after that its normal servicing. It runs a Cam chain that doesn't need adjustment/changing - not a belt. You will however spend a lot at the local servo on 98. Expect double to what you pay in the tida.
2.Do the Series 2 M35 Stageas have any known issues (e.g, weak components)?
Haven't found any specific to the S2 yet. Normal M35 items are suspension bushes, brakes wear pretty quick, wheel bearings have been known as an issue. The turbo on nm35's but we don't have to worry about that. Oh, and the 6th cylinder plug hole oil leak, they aren't exempt from that either.
3.Are there any turbo/twin-turbo kits for the VQ35DE engine that will fit the Stag? (for after the P-plates, stupid nanny-state restrictions)
Yes the HKS Z33 special single turbo kit will fit on the ARX, but I wouldn't call it a bolt on. There were a few items that needed fabrication / holes made. But still very doable. However it is discontinued, but there are a few floating around. Twin turbo- forget it. front diff, and steering rack on the wrong side means that you won't find anything that fits without major modification.
4.is there anything I should be on the lookout for when looking at an AR-X Stag, aside from the usual checks?
No, not really. ARX's are known to be more used in snow areas than other models. Check the underbody for abnormal corrosion due to salted roads, and steer clear. The trip computer cannot be converted to english yet, and there is no real timeframe on when it will be. Check interior wear is in line with what the odo. reading is saying.
5.For a stock suspensioned AR-X, what wheel sizes/offsets would fit, and which bolt pattern/size do I need?
The wheels you mentioned have terrible offsets. IMO, its hard to put 18's on an stock susp. ARX without it looking a bit silly. Better off keeping the stockies.
Finally, while I'd love to recommend one to you, its just not really a first car. Get a small economical 4cyl hatch. Learn to service it yourself and fix problems, what costs are like for Rego, green slips, comp insurance, running costs etc. Then when your up and running (read- have a decent job) and learnt your hard knocks (ie- crashed the car, yes it probably will happen at least once) think about getting something more suitable to your lifestyle be that sporty or 4WD or whatever.
Finally, the website has a great search function, that will answer most of your common questions. There has been a few prospective owners post up. Sometimes the conversation gets a bit off topic, but the info is there.
On a random note, I noticed you are in Brisbane (i think?)
Im not sure of the P plate laws up there, but here in vic, every variant of the m35 Stagea is ruled out for P platers apart from the nm35 250RS (2.5 n/a variant)
Probationary drivers can drive PM/PNM35's legally.
They are not on Vic roads, or RTAs prohibited cars list.Doesn't even exist on the list, which means its acceptable in Vic if it has
No Dramas.
I had to explain what it was to my insurer, as they didn't have it on their "list", even though they had NM35s. I got the "are you sure it isn't a ARX?" thing.
Which brings me to OP- Insurance will rape you. Hard. Get a quote.
Yes yes insurance.... Import, your under 30, your under 25, and your under 20, your on your P's
Due to your age you won't have a no claim bonus..
Just be perpaired to be raped for full comp insurance, I'd expect you will be paying over $2k full comp/yr or there abouts.
So shop around.
As you said the biggest engine you can drive is an N/A 6 cyl on P's.
Bloody heck I brought all my cars including my 1st... Go buy an r31 or an NA s13 for a few grand.. Leant about them.
Even Better something with carbs to learn the basics. Nothing wrong with simple old school ;)
1st car, man
Thanks for the helpful info PN-Mad. I thought that the stockies on the AR-X were 18"?
No Dramas.
I know that already, my uncle got raped repeatedly for insurance on his old C34 Stagea a few years ago, it used to cost him more to insure it than it cost my dad to insure his HSV Avalanche :rofl2:
Yes mate, they are 18's. Problem is people buy aftermarket wheels and go low profile. Makes em look silly. You have to work hard to find something that looks good and fits. Even my 19s look small sometimes, you park it next to a R34 GTR with 19s and my wheels look tiny! They swallow wheels.
Concentrate more on if the car is suitable first before thinking about wheels. Your mates will go out and buy little sports cars on their "p"s, and you've got a wagon. You gunna be Jelly?
On a random note, I noticed you are in Brisbane (i think?) Im not sure of the P plate laws up there, but here in vic, every variant of the m35 Stagea is ruled out for P platers apart from the nm35 250RS (2.5 n/a variant)
I just double checked, in QLD, I can drive any N/A Stag without worries, and I can apply to drive a turbocharged Stagea after getting an application form from TMR. The M35 Series 1 AR-X (with it's extra 110kg over the other models) makes its power-to-weight ratio 121kW/tonne, which just sneaks under the limit of 125kW/tonne for the moderately-powered turbo/supercharged vehicle exemption (http://www.tmr.qld.gov.au/Licensing/Getting-a-licence/Car-licence/Provisional-licence/Restrictions/High-powered-performance-vehicles.aspx), and it has less than 210kW.
I'd probably go same/similar profile, small wheels and low profile tyres on something with as big wheel arches as the AR-X would be ugly as. Also, I've never really been the type of person that gets what everyone else does. I mean, when other silly people buy Beats, I always bought headphones that were better and cheaper. Also, I can always tell them it's pretty much a Skyline wagon (which it kinda is, same engines and similar base platform).
PS: Stop posting when I'm typing a post, xD
I won't lie, I had to google wtf a beats was... Feelin old now....
Look, I still don't think it's a great first car. Most of us here got some form of shitbox first car. We worked on it, and learnt heaps because we fixed it every weekend. Even if it's for a year or so. It's a good idea, think it over.
My first car was the worst of the N13s, the 1.6. Manual though, and I had a great time in it!
These days, get an N13 SSS, or one of those N15 Autech's that iron chef is bringing in. you'll have a great time and it'll be cheaper to fix.
Car I miss the most is still my R31 though. :-(
No Dramas.
i had the same thing when getting the AXIS insured etc they didnt know what it was......... i'm like NO it isnt an ARX
So shop around.
1st car, man
i'd be guessing over the $4000 mark LMAO
Lol... out of interest I did a quote online just car- Comprehensive. 17yo male, morningside (I have no idea if thats a dead shit suburb or not) $22k purchase price. Just got licence. On a 2003 Stagea- $3605
Thats enough to buy my Mazda every year! lol.
Speaking of which, what would it cost for a N/A 2+2 300ZX? Was looking at a couple on Carsales instead of Stags for a change, xD. Seems like it would be a better first car than the Stag, plus I can always retrofit twin turbos later (with some difficulty).
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
