Hey all,
I will be getting my P-plates next year, so my parents are helping (read: paying for 75% of) me buy a new car so I can stop driving my mum's Tiida everywhere (god I hate it, it's like it has no noise isolation in the cabin). I quite like the looks and practicality of the AR-X FOUR, but I have some questions about them:
  1. What are the maintenance costs like on a Series 2 AR-X FOUR?
  2. Do the Series 2 M35 Stageas have any known issues (e.g, weak components)?
  3. Are there any turbo/twin-turbo kits for the VQ35DE engine that will fit the Stag? (for after the P-plates, stupid nanny-state restrictions)
  4. is there anything I should be on the lookout for when looking at an AR-X Stag, aside from the usual checks?
  5. For a stock suspensioned AR-X, what wheel sizes/offsets would fit, and which bolt pattern/size do I need?
  • Replies 50
Posted Images
After doing a little more reading, I know that I'll need a PCD of 114.3mm on the wheels for them to fit correctly, but looking at the sizing for a set of Versus Turismo Spada Ottimo 18-inchers (http://www.rayswheels.co.jp/cgi-bin/cgi2/english/sizeGuide.cgi?modelName=OTTI_S), I need to know what specific inset/hub clearance I'll need. Also, for an 18" wheel, what tyre size would fill the guards on an AR-X nicely without looking horribly out-of-proportion (too low/high profile)
1. Depends if you work on it or pay someone to service it, and how you treat it.
2. No, think of a Series 2 V35 Skyline with a wagon body.
3. Bolt on? Not if AWD. You will need to modify a single turbo kit's piping. TT kits are not possible due to front driveshaft. RWD? Yes, same as V35/G35.
4. Like what? Unusually high water damage?
5. Feel free to use the search button for info regarding this and also for tyre/wheel calculators, You will need the rim width and offset.
1.What are the maintenance costs like on a Series 2 AR-X FOUR?
Not that different to other cars. Other than engine oil/filters brakes and tyres, there isn't that much to do. The initial cost of changing all the fluids in the car is high, as there is a lot to do, but after that its normal servicing. It runs a Cam chain that doesn't need adjustment/changing - not a belt. You will however spend a lot at the local servo on 98. Expect double to what you pay in the tida.
2.Do the Series 2 M35 Stageas have any known issues (e.g, weak components)?
Haven't found any specific to the S2 yet. Normal M35 items are suspension bushes, brakes wear pretty quick, wheel bearings have been known as an issue. The turbo on nm35's but we don't have to worry about that. Oh, and the 6th cylinder plug hole oil leak, they aren't exempt from that either.
3.Are there any turbo/twin-turbo kits for the VQ35DE engine that will fit the Stag? (for after the P-plates, stupid nanny-state restrictions)
Yes the HKS Z33 special single turbo kit will fit on the ARX, but I wouldn't call it a bolt on. There were a few items that needed fabrication / holes made. But still very doable. However it is discontinued, but there are a few floating around. Twin turbo- forget it. front diff, and steering rack on the wrong side means that you won't find anything that fits without major modification.
4.is there anything I should be on the lookout for when looking at an AR-X Stag, aside from the usual checks?
No, not really. ARX's are known to be more used in snow areas than other models. Check the underbody for abnormal corrosion due to salted roads, and steer clear. The trip computer cannot be converted to english yet, and there is no real timeframe on when it will be. Check interior wear is in line with what the odo. reading is saying.
5.For a stock suspensioned AR-X, what wheel sizes/offsets would fit, and which bolt pattern/size do I need?
The wheels you mentioned have terrible offsets. IMO, its hard to put 18's on an stock susp. ARX without it looking a bit silly. Better off keeping the stockies.
Finally, while I'd love to recommend one to you, its just not really a first car. Get a small economical 4cyl hatch. Learn to service it yourself and fix problems, what costs are like for Rego, green slips, comp insurance, running costs etc. Then when your up and running (read- have a decent job) and learnt your hard knocks (ie- crashed the car, yes it probably will happen at least once) think about getting something more suitable to your lifestyle be that sporty or 4WD or whatever.
Finally, the website has a great search function, that will answer most of your common questions. There has been a few prospective owners post up. Sometimes the conversation gets a bit off topic, but the info is there.
On a random note, I noticed you are in Brisbane (i think?)
Im not sure of the P plate laws up there, but here in vic, every variant of the m35 Stagea is ruled out for P platers apart from the nm35 250RS (2.5 n/a variant)
Probationary drivers can drive PM/PNM35's legally.
They are not on Vic roads, or RTAs prohibited cars list.Doesn't even exist on the list, which means its acceptable in Vic if it has
No Dramas.
I had to explain what it was to my insurer, as they didn't have it on their "list", even though they had NM35s. I got the "are you sure it isn't a ARX?" thing.
Which brings me to OP- Insurance will rape you. Hard. Get a quote.
Yes yes insurance.... Import, your under 30, your under 25, and your under 20, your on your P's
Due to your age you won't have a no claim bonus..
Just be perpaired to be raped for full comp insurance, I'd expect you will be paying over $2k full comp/yr or there abouts.
So shop around.
As you said the biggest engine you can drive is an N/A 6 cyl on P's.
Bloody heck I brought all my cars including my 1st... Go buy an r31 or an NA s13 for a few grand.. Leant about them.
Even Better something with carbs to learn the basics. Nothing wrong with simple old school ;)
1st car, man
Thanks for the helpful info PN-Mad. I thought that the stockies on the AR-X were 18"?
No Dramas.
I know that already, my uncle got raped repeatedly for insurance on his old C34 Stagea a few years ago, it used to cost him more to insure it than it cost my dad to insure his HSV Avalanche :rofl2:
Yes mate, they are 18's. Problem is people buy aftermarket wheels and go low profile. Makes em look silly. You have to work hard to find something that looks good and fits. Even my 19s look small sometimes, you park it next to a R34 GTR with 19s and my wheels look tiny! They swallow wheels.
Concentrate more on if the car is suitable first before thinking about wheels. Your mates will go out and buy little sports cars on their "p"s, and you've got a wagon. You gunna be Jelly?
On a random note, I noticed you are in Brisbane (i think?) Im not sure of the P plate laws up there, but here in vic, every variant of the m35 Stagea is ruled out for P platers apart from the nm35 250RS (2.5 n/a variant)
I just double checked, in QLD, I can drive any N/A Stag without worries, and I can apply to drive a turbocharged Stagea after getting an application form from TMR. The M35 Series 1 AR-X (with it's extra 110kg over the other models) makes its power-to-weight ratio 121kW/tonne, which just sneaks under the limit of 125kW/tonne for the moderately-powered turbo/supercharged vehicle exemption (http://www.tmr.qld.gov.au/Licensing/Getting-a-licence/Car-licence/Provisional-licence/Restrictions/High-powered-performance-vehicles.aspx), and it has less than 210kW.
I'd probably go same/similar profile, small wheels and low profile tyres on something with as big wheel arches as the AR-X would be ugly as. Also, I've never really been the type of person that gets what everyone else does. I mean, when other silly people buy Beats, I always bought headphones that were better and cheaper. Also, I can always tell them it's pretty much a Skyline wagon (which it kinda is, same engines and similar base platform).
PS: Stop posting when I'm typing a post, xD
I won't lie, I had to google wtf a beats was... Feelin old now....
Look, I still don't think it's a great first car. Most of us here got some form of shitbox first car. We worked on it, and learnt heaps because we fixed it every weekend. Even if it's for a year or so. It's a good idea, think it over.
My first car was the worst of the N13s, the 1.6. Manual though, and I had a great time in it!
These days, get an N13 SSS, or one of those N15 Autech's that iron chef is bringing in. you'll have a great time and it'll be cheaper to fix.
Car I miss the most is still my R31 though. :-(
No Dramas.
i had the same thing when getting the AXIS insured etc they didnt know what it was......... i'm like NO it isnt an ARX
So shop around.
1st car, man
i'd be guessing over the $4000 mark LMAO
Lol... out of interest I did a quote online just car- Comprehensive. 17yo male, morningside (I have no idea if thats a dead shit suburb or not) $22k purchase price. Just got licence. On a 2003 Stagea- $3605
Thats enough to buy my Mazda every year! lol.
Speaking of which, what would it cost for a N/A 2+2 300ZX? Was looking at a couple on Carsales instead of Stags for a change, xD. Seems like it would be a better first car than the Stag, plus I can always retrofit twin turbos later (with some difficulty).
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
