Found this. Looks like that signal is the opposite of what we want. Bummer 'cause that would have made it pretty easy.
Edited by Commsman
How old was that post Craig? You gotta get out more...
I gave up on the anti lag, it didn't help much as the stally has been returned to a stock stator, and there is no possibility of it ever making boost. Yours would be a different story. I had plans to test another method to pre spool the turbo, compressed air, but this isn't the car to test that theory on. lol.
I can see mine going rwd manual very soon anyway which gets right around the launch issue. Or perhaps I will drop back to a highflow again for launch boosts, and so the gearbox isn't having quite so hard a time.
Anyway, back on topic, the neutral signal will work one way or another, but if it's 12v then it will be a simple strip and twist, nice and easy for a DIY with pics. I will take some shots when I test this out on the next car. (Damn Leon, you beat me to it. Looks like we will need a relay.)
Relay will probably work as 0V is normally an earth, but sometimes it is just 0V.
But all is not lost for a dead simple solution. Why not use the Start signal on Pin 42? According to my research, that wire has 9-12V when key in start position & 0V otherwise. Sounds perfect, yes?
DIY instructions:
1) Cut wire on Pin55 a few inches from the ECU connector. Strip ECU end & tape up other end.
2) Strip small amount of insulation from wire on Pin42 (leaving wire intact).
3) Solder Pin55 wire (ECU side) onto Pin42 wire & tape up.
Job done :thumbsup:
Testing & pics are all yours Scotty. I'm not moving mine from where it is as works just fine, but the above is certainly an easier solution....if it performs as expected.
  • 3 weeks later...
so has this been tried and tested yet??
DIY instructions:
Job done :thumbsup:
  • Like 1
would i need to install a diod if i went this option
If you don't want to install a 'valet' switch then you don't need a diode when you connect any 12V source, be it from reverse lights, another pin on the ECU or anywhere else.
Ideally a 12V source close to ECU is best. Just need one that is 12V only at times when you don't need full throttle; eg reversing or starting the car.
The only location for reverse lights that I have found is at the rear, so not very convenient (although I already had a spare wire left over from TV install) & the start signal on the ECU is certainly convenient, but Scotty thinks it may not be active long enough to keep the code clear (although I think it should be OK 'cause when mine put out a CEL it would only take a few seconds with the switch thrown & pedal pushed to clear it).
Why don't you give it a go & let us know? If you do the mod you should know in 500km or so. Cutting one wire & joining it to another seems to be the simplest idea we've come up with so far.
Because it will have looked for the brake wire signal & generally spotted a fault in that time.
Mine sometimes goes weeks without throwing the fault; so it can be a bit hit & miss.
Mine takes about 5 seconds to reset. Still worth trying it, as a quick supply of power might be enough to stop the light from coming on, instead of the few seconds to override the light.
One thing I have noticed is I get better fuel consumption with the light on.
You will.....it will go lean.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
