Midnight Purple - 1995 R33 GTR V-Spec
This car is perfectly built to be an above average modified street GTR that you can take to the club level circuit days on weekends reliably and without issues. Or really have some awesome fun in the hills. The suspension setup on the car is really something else, if you are interested and come check it out you’ll see what I mean when test driving.
Don't buy other overpriced R33 GTRs with a stock motors and bolt-on's - spend a few more $$$ and grab one with a proven reliable motor & setup and save yourself the rebuild bills down the track
All modifications have been carried out in house at Racepace Motorsport and the car has been serviced every 5,000kms or less.
Motor:
R33 RB26 rebuild by Racepace Motorsport. Includes forged pistons, forged rods & R33 GTR crank.
Head was fully rebuild, ported & tidied to Racepace custom specifications. Enlarged oil returns & restrictors - track ready/safe motor.
PowerFC Pro Edition (comes with ignition cut & launch rev limiter).
Garrett -5 Turbos, Tomei dumps into Apexi front pipe & 3” exhaust cat back. (10,000km old turbo’s).
9.5 LTR Racepace Sump - Winged/Gated (8,000km old).
GReddy FMIC
Large Oil cooler with Filter relocation.
Sard 700cc Injectors (10,000km old).
Nismo AFM’s with stock airbox & K&N Filter (10,000km old).
OEM Coil packs.
Nismo intank fuel pump.
Custom catch can & washer bottle setup
Suspension/Brakes:
Racepace Tein RS coilovers – Custom spec, re-valved and configured. Believe spring rates are 8 front & 6 rear.
Racepace Modified stock upper arms.
D2 Racing 356mm Brake kit upgrade. Ferrodo DS2500 pads Front/Rear. ADR Brake lines. Cusco Brake Master stopper.
Drivetrain:
Nismo Coppermix Twin Plate clutch
Nismo 1.5 GT-Pro LSD – Rear (1,000km old, freshly run-in).
Nismo 1.5 LSD for GTR – Front (5,000km old).
Rebuild & Modified 4WD Transfer case – Extra front drive, excellent improvement out of corners over standard.
Cosmetic:
Series 3 Front lip
ARC Air deflector panel
Nismo Dash & centre gauge cluster.
Full motorised Ganador mirrors
Brand New Sparco suede wheel
Interior is overall in very good condition. No tears in sets etc.
Makes ~360rwkw @ 19psi on a conservative track tune. If you wanted more power just put a 3.5” exhaust on and more boost.
Or E85 and see 400rwkw like everyone else does.
There is probably other stuff I've forgotten to list in the above. I'll update as i remember bits & pieces.
Price: $33,000 - 6 months registration, RWC upon sale and has just been serviced.
Price is negotiable if you do not want some of the listed spares below.
Spares & extras: – These are included in purchase price, over $4,000 in extras
AutoSelect Full Carbon insert dash, centre console, door insert/handbrake boot
R33 Series 3 Door trims.
Set of Xenon headlights (average condition).
Set of R33 GTR wheels with Hoosier Drag Radials 275/17, hardly used, 6 months old and Stored correctly.
Carbon Fibre rear diffuser.
New Sparco Harness.
Mines Rear wing carbon insert (needs repair).
HKS EVC 5
Overall body condition is excellent. Front end is in excellent condition.
Stickers will also be removed before sale, body come up exactly how it was pictured below prior
Upon sale car will have R34 GTR wheels with tyres fitted.
Wedsport SA90s fitted with 285/30/18 AD08s, will not be sold with the car at listed price. Price to be negotiated if buyer is interested.
Enquiries via PM or Forum Email
post-709-0-73123400-1334741085_thumb.jpg post-709-0-56036100-1334741086_thumb.jpg post-709-0-43613900-1334741087_thumb.jpg
Thanks.
Need money for other ventures at the moment.
If I didn't I'd just keep it given the amount of money I've put into it in the last 6 months with new diffs/sump/brakes etc.
GTR's are not full time AWD. Quoting rwkw is perfectly normal, most results in the RB26 dyno thread are done in this fashion.
If you want to know more about the GTR ATTESA system, and how little difference it makes to dyno results - use the search.
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
