Its a 4202.... on 12 psi....... with a standard engine....... just cam and springs..... Through an auto....... in full street trim/Exhaust.
Made 695 on 17 psi and never had an issue...... ever....... The engine never died, never cracked a piston from this "timing drift" I hear so much about.
The 1JZ is also a stock engine. No cams, No springs. No Pistons, nothing.
Went 9.1@153 in a 3050 lbs car. Quickest 1JZ in the country and yes runs a wolf.
We also have track cars, street cars, targa cars, boats and even hovercrafts that run wolfs.
We dont have the dramas everyone else seems to plague these ECU's with.
But, we also have cars that run Mircotechs.... and start in the mornings... ans run 9's.... with stock engines.
We also tune Motec's that drive like dreams, Autronics that start and run and power the quickest single cam VL in QLD.
Haltechs, EMS, Link They all work in there own respect..... Some ECU's are better than others than some things....... but you use the correct ecu for the application.
If some one wants the best on board logging.... do you use a microtech or a wolf?
What about PWM control over wheel speed and TPS do you use a Haltech? Or direct fire ignition on a V8?
2 Step... over wheel speed would you use an EMS?
Budget...... Motec?
I think not. Every ECU has its place in the market. I hate to say it but its the tuners that wont take the time to work out where an ECU will work and when it wont that cause the most trouble to the end user.
End rant.
Yeah maybe one day you'll learn how to tune them and they won't seem so bad.
You made the wrong choice. The Autronic is still a better ECU
Anything can be tuned and we have no issues tuning them, i could sit here and post a million fast cars with any ecu on the market, microtech would kill wolf if that was the premise on choosing an ecu but its not...
There is no pissing contest, i don't have to defend any particular brand of ecu.... the car i bought is neither from you or involved with with your business.
We get asked all the time to sign up to particular brands but we prefer to use the best ecu for the job,to be objective this requires us not to be tied to any particular brand.... objectivity will always be the backbone of our business..... its what allows us to remain a tune only business.
As it is ours also but when an ECU does everything better than the rest, why not promote it? I do what I feel necessary to ensure the brand I like gets a proper plugging. We have cars using every different type of ECU. Some we have removed to replace with others that do a better job.
You are the one who mentioned having a piss on and burn party. I'm not sure why you are so scared of the V500/550. We get the absolute best results when using them
TBH looking from outside the dealer perspective i can yes v500 and v550 do do a good job, better than the rest? well beauty is in the eye of the beholder.
on a lighter note as shit got way to serious.. our new acquisition is a v4... so im sure we both agree its an anchor :P
Like status has said. Anything can be tuned. Hell we even to a carby turbo 308..... May as well be a bucket with a hole in it but it works and its fast. Bloody fast.
Its not The injector/coil control that I like about the wolf. Its the fact that when My customer says...... I would like to run boost over wheel speed. I can say yes no worries. But limit it when the engine is cold, yes no problem.... But I don't want to run more than 22 psi on transbrake.... yes not a drama. But I want my nos to turn on at full throttle, only when the the car is at 0 kph, only when its at 1 psi then turn off at 17 psi so I can leave off my transbrake at 22 psi with no gas. Yep easy as.
Or I want to switch my AC on, and make my pump turn on, then 1 second later my fan to turn on, but turn off over 80% throttle or under 600rpm.... or when my cabin temp is below my desired input temp.
Auto trans control, PWM line pressure over throttle position, Anything over anything with anything controlling it.......... Its only limitation is your imagination.
Show me an ECU that can do this under 2k, with no additional add ons, upgrades or unlocks.
Back on topic, yes Autronic SM4 is a great ECU. Just run there disk in your cas and have years of trouble free motoring and awesome injector control
Edited by HYPED6
E1280s from adaptronic.... but you have to deal with the software which personally sucks a little life everytime we do one :P
Honestly haven't had the pleasure yet.....
Ever had a scope on the coil charge time under snap throttle conditions?
haven't had the need to dig the scope out for awhile tbh.
sounds like you get alot of *special* customers... lol
try a vipec... its very flexible like that.
Totally agree its amazing that there are big branded ECU that havn't got the basics(fuel and timing) sorted and yes I've scoped alot of ECU's with various issues and it does keep them honest. I've tuned a few WOLF V500 and some have been ok - I had one that overheated and would cut injector output.
I still think as far as a engine control system goes the autronic is still years ahead of the rest. You can do all those things you said before but you can add actual PI control loops ontop - with PI loops that actually work. The other biggest seller for me with the autronic that no other aussie ECU's I've seen (motec, haltech, wolf etc) have is idle delta igniton timing.
You can do idle ignition timing with a few ECU's....... Autronic is by far the easiest to set up in that regard.
Others you need to do 4D and 5D outputs, but it still can be done.
They also have the best logging, bar none and are as reliable as anything. Individual cylinder control over load and RPM.
I rate them very highly as an ecu and tune many of them.
The new Wolf V550 has PI control on there outputs. I haven't had much of a play with them yet but im sure I will get the chance.
Haha, every customer is *special* in their own way. We try to cater for everyone in that regard but sometimes when you see someone who just says they want it to be a burnout car and nothing else, you can tell in the back of your mind they will never use it for that at the end of the day....it will end up being their daily driver instead and they will complain about the ECU 'they' selected. It's always better to have a little bit of overkill for those ones.
BTW are you still tuning over in the land of sand? How is/was it?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
