  • Replies 107
Yes if you ask a meaningful question
Posting up an online catalogue is pointless
Even more so when you put the exact same post in your build thread
thought the pics were pretty lol and fair enough i know ive asked some stupid questions and posted some useless shit, but hey least it gives people something too do haha
yep righto bro setup looks mint should see your 300 at the treads, hope uve got a healthy box and diff... also.
hellapost... post count is everything lol
Ahh diff yes its a nismo 2way :rolleyes: gearbox noo :unsure: 2nd is abit crunchy when cold lol, im not sure if i should just slap a 25box in or get the 20box built.
Bahahaha Zebra. I knew by the thread title that this thread was gonna be awesome.
51NNA. You're embarrassing yourself. I believe I mentioned about coming on here and telling the experienced members that they don't know what they're on about lol. Might be worthwhile actually finding out about Zebra's Supra before you say it's a piece of shit and he has no experience.
On topic, your setup looks good, it will get the job done. What was the point of the thread though? I think Zeb is on the money. Can haz wasteland nao?
Couldnt care less what anyone thinks, especially forum heros usally change there tune once met in person...and why would i give a shit about a toyota? im not on supras australia?
Edited by 51NNA
Haha you guys still think that that obviously LHD supra with the te37s is really mine?
Awesome lol
Crafty motherf**ker.
51nna, what tune lol? None of us are acting tough or threatening you.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
