Cheapest way I can think of is one of the $99 TV tuner cards. Most (if not all) have hardware video capture built in. I'm not sure what sort of quality it is, but it'd easily be better than VHS.. :)
  • Replies 57
revhead: ive never used the hardware capturing on the tv tuner card, i might have to investigate this! i'll connect the vhs recorder to it later today :)
goon: the camera was on a suction cup mounting bracket on the rear windscreen...was awesome. but now i think wakefield will only permit passengers to carry cameras or if its mounted it needs to be caged up...as for it being too close for comfort? nahhh i knew what was happening :)
haha, damo has a bit of hardware now installed on his car! he's definately going to have some fun!
yup, dopey, lots of fun! even for a punter like me!!! i remember my first time out, you couldn't wipe the grin off my dial for the whole day, was awesome :)
wld33r: afaik, there is one other skyline going down. i think its a 33 gtst. your friends are wrx'y guys? cool!
i have some more vids, but i dont have anywhere to put'em up :rant: i have 3 compilations a mate put together from back in 2000/2001 which include an original 22B and GTR700 in its former self ;)
i remember they were building one, i dont remember they building eric's typeR though? in any case, how fast is fast :) :) :)
i've got 3 new video's being hosted soon :) unfortunately, they are of my early WRX days and the fun down at wakefield i had :) you might notice an authentic WRX 22B and a familiar purple R33 GTR (GTR-700) in its former self too :)
edit: here they come :)
http://www.boostn247.com/wakefield/Kicksta...tartmyHeart.wmv
http://www.boostn247.com/wakefield/VideoWakefield.wmv
not Eric's car.. Brian's Type-R. Wheelspin in 4th gear when VTEC kicks in on Toyo semi-slicks (not wide enough, need new rims + tyres). crazy lol... hopefully we'll find out how fast on Thursday :)
Eric & Ben will probably go at it all day again.. Ben's got TODA 288 cams in his sprinter now... :)
frank where did u get this vid??? russ and a passinger (jimmy) are working with me... russ just gave me his full tape... THAT'S SOME GOLD... he was very lucky tho... 'only' stuffed one off the rims + tyre...
eeeeh if i didn't sell my r33 i would'we been there :rant: with them :)
ps. we'we been HAMMERING him for this for few days now...
CHEERS
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
