Does your overdrive button work at all? Mine stop working, It was in overdrive all the time and now and then the button would work and could take it out of overdrive... Yeah it what we thinking what it was doing... Playing with the button now, You can see the pin with the plate going for over the place when you push the button in and out.
I know with mine, the faster you went, the wrost it got. It sould like you got the same stutter as me...
What happens when it starts to stutter and you take it out of overdrive and then put in back in? With mine when the overdrive button worked, It would stop for a while and then would start away.
Would take the overbutton out and see how the pin moving around when you push it in and out and also take it apart and clean it, Clean mine few times and it did work of abit. Also take the gear lever out and check to the wines for the overdrive to see if they are not broken ect
I know mine off trademe. they are hard to find... But try trademe and the nissan place in chch...
Yeah the OD button seems to work ok. If I'm cruising and it starts to stutter, I can back off throttle, punch throttle or turn off OD and it will stop. But if I stop if by turning off OD, it will usually start stuttering again (while not in OD) within a minute. That's whats the transmission guy thought was strange - it stutters out of OD.
I'll check out the OD connection once I have the radiator back in (pump and belt change in progress).
So does it stutter in 3rd gear? My old gear box does a stutter in 3rd gear before we swap the gears over.
We going pull down the old gearbox in next few weeks and see if what we can find and we going to send the old torque converter to be cut open and see what going on with it.
I'm sure it the torque converter/gearbox/overdrive.
Ill let you know what we find.
Have you sign up to SDU?
If by 3rd gear you mean Drive without OD then yeah it does.
Keen to know what you find out about your old box - sounds similar to mine.
Haven't joined SDU - didn't seem to be much (any) technical/mechanical info there...
  • 2 months later...
Hey hutchwilco, How are you geting on with your Stagea? Found the problem yet?
I sold my Stagea few months back :(
I've only just got it back into one piece - did cambelt, (water pump (was leaking)) etc then found the rear shocks had leaked out, and brakes were skewee so only bout to start it up again in months. I found while I was doing the cambelt that the exhaust cam was one notch -7.5 deg - retarded, dunno if that could cause some kind of stutter but we'll see.
I see a transmission on tardme for 80 so I might buy that as insurance. Should know by next week if the stutter is still there.
yep cheers, will have to test both those theories. I bought a consult kit for nothing on trademe, so will set that up to watch what the solenoids doing.
Thing is it stutters when not in OD. guess that could still be a rogue activating solenoid.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
