Hey,
Thought I'd give you guys a chance at this stuff first, Need to clear out the garage to make room to build a new motor
Going Cheap as chips
RB25DET (R33) block, with girdle needs a re-bore - $0.05 ono lol
RB25DET crank, very good nick, hasnt seen the inside of an engine since a refurb, standard size journals $50
2JZGTE cylinder head, stripped down for inspection, has all valves/springs buckets/cams etc, needs valvestem seals, comes with cam covers and Cam postiton sensors - $200 (yes I though worth double that)
Greddy E-01 Boost controller, comes with 3Bar Greddy Map sensor, but missing the solenoid (same unit as the Profec-B) worked last time I had it pugged it, $50
Drift Branded reclineable seat Blue in Colour, bit faded and a few threads pulled (cats got to it) fairly certain it still has skyline rails - $50
KKK K27 7200 11:11 Turbo, Porsche 930 turbo spec, could do with a rebuild T25 flange .60 A/R turbine, was nice and responsive on my RB25, the turbine flage has modded to allow it to bolt to T3 manifolds (was done before I got it) also $50
4x 16x7 +40ish Toyota Soarer wheels with worn rubber (note despite these being 5 x 114.3 they do NOT fit skylines, the hub centre is too small may fit with spacers though ) - $100
I'll also put my bike in here too
1988 Suzuki DR250S trail bike, no rego, runs well, has new head and tail lights - only selling because my knees are stuffed and its too hard for me to start - had this sold, but never eventuated, wouldnt need much to be registered maybe a back tyre ($100) and a spring for one of the pegs, the seat is a bit torn, but as a muck around bike it is great, very reliable bikes these things
Has the 22HP motor from factory (non S models had 17hp)
$800
Photos to come
All prices are + Post and located in Canberra
Get in first or it all goes on ebay (with a price increase)
Cheers
Andrew
https://www.sau.com.au/forums/topic/398344-clear-the-garage-fire-sale/
  • 1 year later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
