Rb25/30De With Rb26 Itb's Best Fab Method? Not A Conversion Plate
Hey Crew,
I have an RB25/30DE Setup in a C210 skyline.
I have just bought a full RB26 manifold and have a spare RB25 manifold ready to chop up.
I also have the RB26 flange plates that we will weld to the RB25 cut down manifold.
My main question is.
has anyone just cut the RB25 and RB26 manifold put them together and welded them shut or are the runners too ofset to do that?
Im trying to minimise the overall length of the set up for clearance issues to the brake booster.
Thanks in Advance
Not interested in a conversion plate so please dont suggest it as an option. not a fan of the injector position once its been moved 20mm away from the head.
I can say with adapter plates and the greddy plenum on the 26 throttle bodies on a 25/30 will hit the clutch master cylinder and hit the lines exiting the brake master as well. So far 12mm packers under the sub frame has fixed the issue. However with a factory rb26 plenum it is fine with good clearance everywhere. In a r33 gtst engine bay. Possibly pointless info there, but in case any one wants to know. The adapter plates are 12mm thick each, so 24mm packed out from head.
Personally I would try and make the runners as long as possible for an NA car, especially when it has relatively small capacity....well compared to v8's, and lacks the bottom end torque to fill in the power curve down low.
Personally I would make a completely new flange/manifold to incorpoate the ITB's to suit the cylinder spacing.....it's not far off at all anyway. Is welding th ITB's to a flange an option?
Ariel
  • 3 weeks later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
