So, I've had this car for almost a year and I have never noticed this, hence why I'm here.
Let's say your driving off boost. Then you push the throttle a little further until you make boost, as soon as it goes from 0psi to positive boost, there's a click, like a relay click, coming from where the boost solenoid is in the bonnet.
Has it always done that? Haha. I'm paying a lot of attention to it now... Grrr
Thanks
https://www.sau.com.au/forums/topic/399393-can-you-he-the-clicking/
It must be quite common, had to follow my old man his pathfinder recently, when we went onto the motorway on ramp I was going to fly past him, but just before thought I felt something vibrating in the back and ended up not even keeping up with him! :action-smiley-069: haha, car's been fine since
Edited by WMDC35
yes, if you turn the ignition on you should hear it clicking as the solenoid opens and closes.
mine sounded like a playing card in bicylce spokes haha
He is right, I shat my bricks when I heard it too. Put the ignition to "on".. "click" i kept wondering for a couple of days and with some research it was the solenoid.
yes, I get that all the time haha
usually after I give the car a squirt...spend the next hour listening for broken bits lol
This is exactly the same as me
I've spent every drive since my tune listening and popping bonnet.
So much so that my bonnet cable is farked
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
