Hi,
Im selling my R32 gts-t with or without plates. Its got some spray painting to be fixed but yet ill post different prices for it top be sold painted or not.
The only mods to it is air filter and been lowered. Its blue in colour with a sun roof (pimp window lol). Its got a GTR front bar and side skirts ready for it (need to be painted). Got 3inch exhaust from turbo back.
The damage has been fixed, new front quarter (needs sprayed), rear quarter had a few dints that has been fixed. The 3 price options are as follows:
Option 1. (as is, NO PLATES)
Meaning:
*Front & Rear quarters need painting
*Side skirts need painting
I will take $11,000 as is without plates.
Option 2. (Painted, NO PLATES)
Meaning:
*Everything sprayed
*NO plates
Im willing to take $13,000
Option 3. (everything sprayed + plates)
Meaning:
*Everything sprayed
*WITH plates
Im asking $16,000.
The damage was slit, it has been fexed just not sprayed yet.
If you would like pictures of the car, please leave me you email or PM me.
NOTE: The car is in Sydney
Thank You
https://www.sau.com.au/forums/topic/39953-1992-r32-gts-t-plates-utryd/
  • 3 weeks later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
