How much are you willing to spend? Off the top of my head these would be my preferences $$ aside - in order of preference, for the power and boost level on E85:
1 - Borg Warner EFR8374 with .92a/r housing (internally gated T4) will easily make that power at that boost level on E85, designed to run on petrol engines so should handle the heat etc - and should be the most responsive turbo out there which will comfortably do that power
2 - Borg Warner S300SX FMW with .91a/r housing (externally gated T4), laggier than the EFR (arguably a little more responsive than the PT6262) capable of similar power to the EFR. Nudges out the PT6262 for me due to having a less dodgy track record in terms of reliability.
3 - Precision PT6262 with .84a/r housing (externally gated T4) will also easily make that power level on E85, though is by reputation laggier than the above two options - which comes with its ability to make power than all the other options. Potentially redundant as all of the turbos I am mentioning will do over 400wkw at 22psi on E85 with a certain amount of comfort.
4 - Garrett GTX3582R with 1.06a/r housing (externally gated T4) - Probably closest in spool and power potential to the PT6262, marked it lower because of hearing too many horror stories regarding the TS housings on these failing when used in anger, would like hear things which give me some confidence that this is an ATP-version specific problem, or something which has or will be dealt with.
On ethanol 22psi is low boost imo, as long as you have a modern compressor wheel that will cope with the higher pressures, without generating too much heat. Good cooling will still be required obviously. Is it to be a track car? Built engine?
The GIO Gibson 32 GTR was running over 40psi in race trim on stock looking old tech turbo's, reliably.
I'm aware it's on the low side, I will probably run higher boost for fun times but at the track (yes track car) it will be around that boost level (20-22psi).
Good cooling, HKS oil cooler and HKS Type R intercooler, stock radiator but will upgrade if needed, stock motor with 1.2mm head gasket and mods to hopefully combat oiling issues (pump gears, ati balancer and sump extension)
Thanks for the reply, I'm actually really surprised you didn't suggest a FP HTA GT3582R, it's probably the top of my list
1. Potentially but still worried about reliability and supply
2. Will look into more
3. From everything I can see the 6262 performs exactly the same as a T04Z, which I had and was great but probably looking for better response at the track
4. Another option I've been pondering but 1.06 scares me, do they come in a 0.8ish T4 divided?
Edited by SimonR32
Only didn't mention that because you specified twin scroll - I am unsure what housing they use, if it is of a better material/casting than the ones you get from ATP then yes.... it'd be the winning choice for me. If it was for single entry turbo choice then it would have been #1 for sure :) And in hindsight, I should have mentioned that as I actually mentioned the GTX (wasn't going to include it)
1. Potentially but still worried about reliability and supply Fair enough too. I am starting to feel more comfortable about both, there is a company with the TS T4 EFR8374s in stock - a mate got one within 3 days of ordering from them. The reliability is something that does more high risk because of the epic fail period, though it sounds like a specific cause has been found and addressed so not as concerning as before. Thinking about it, yeah I'd probably lean towards the other options until those other two points are proven to be no longer an issue.
2. Will look into more Sweet, I have the impression the Tilton EVO had a variation of this turbo at WTAC closer in spec to the 9180!?)
3. From everything I can see the 6262 performs exactly the same as a T04Z, which I had and was great but probably looking for better response at the track I would have expected a bit better response from the PT6262 - somewhere between GT3582R and T04Z but haven't experienced a PT6262 myself so could be wrong
4. Another option I've been pondering but 1.06 scares me, do they come in a 0.8ish T4 divided? I believe they do. I've been in a couple of cars running the 1.06 TS and imho they haven't been anywhere near as bad as you'd expect looking at them - nothing like the 1.06 single scroll things
Chris made 440kW on his 26/30 on pump fuel @ 22psi with his EFR8374 .92, so should be able to drop down to the EFR7670 and still get 400kW on juice
Fullrace have told me EFR supplies were supposed to get much better from September, potentially will also have a prefabbed downpipe to suit GTRs soon, all going to plan
Chris made that on a hub dyno with a very aggressive head setup on an RB30. Consider his to be 390ish-kw on a Dyno Dynamics - though I guess that'd still potentially equate to 480+kw with E85 on a DD :D
Tilton had the S300SX with 66mm compressor wheel and 1.00A/R turbine housing, same as what is going on my engine.
Think I've almost convinced myself that this is the way to go, also looking at GT3788R which seem to make similar power/response
Nice, the FMW S300SX I had in mind was also the 83mm variant - just to be clear :) Let us know what you go with, will be good to hear how it goes.
This is the one. http://www.full-race...-fmw-turbo.html
What manifolds have you looked at Simon?
I've already got a T88-34D 15cm kit on the car (as scradly alluded to in his post) so it's a Trust T4 divided stainless job and 50mm gate
Edited by SimonR32
Oh ok, so you intend on keeping the manifold and wastegate I assume?
So far my 83/75 300sx .91 has made 375rwkw on pump at only 18 psi...
That is on a conservative dyno with only tomei 260 cams..
Should make 450 with a bit more boost :D and then add E85!
Interested in your thoughts on your tubro (considering it's very similar to the one I'm looking at)! If you loaded up 3rd of 4th gear on a flat road when are you getting 1 bar of boost?
Honestly I haven't really been driving the car much as I'm interstate atm, on the dyno it makes a bar at around 4500 which a touch laggy but in saying that the car isn't complete yet and the cam gears are set at 0 and running fairly rich, boost is just running off gate pressure as well...
If your super keen PM Piggaz as he will be driving the car out to UNIGROUP on Monday for the fuel system upgrade and retune
Ok I've been trying to research like crazy and been in touch with Geoff at fullrace who recommends either a prototype S300P, S300SX FMW or wait for a EFR8374.
Not convinced that the S300P will make enough power for me, Joeys results from his turbo scare me from the S300SX FMW (as it's similar) and the EFR8374 is still a while away, plus only comes in a large T4 divided external gate option and all three turbos seem like they may have fitment issues on the current manifold.
The Garrett GTX53R doesn't come with a decent twin scroll T4 housing (only seem to be able to find the crappy ATP housing which I'm not at all keen on running)
So that leaves the GT3788R 0.89 T4 divided housing or the PTE 6262 CEA 0.84 T4 divided. Not that keen on the Garrett because I have yet to find many results and it's really an unknown.
The 6262 looks like a winner, I have looked at JEZ's results in a bit more detail and it does look more responsive than a T04Z while still capable of making big power so that looks like the winner.
Now the choice is to get a surge ported from cover or not and where to buy it from...
I did not know the S300P was available? Did he elaborate on the wheel/housing sizing on this?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
