I have searched the forums and can't find the answer I am looking for. Skylines were never sold in my country so mine was specially imported. As such, it is very hard to find imformation on the cars. I am sure it's been covered here (maybe several times), but I am having a very hard time finding wheel fitments for my R32 GTR. The rear fenders have been rolled, so that should help. I am thinking of putting a set of 18 inch Enkei RPF1's on it. I want to go as wide and aggressive looking as possible on an r32. Help please?
Look how far in the current 17 inch wheels are. Not awesome.
This is my car with 18x9.5 +12 if that helps.
That does help some, thank you. Is 9.5" the widest one wants to go on a R32 GTR? Do you have any other pictures you have posted I could look at from different angles so I can get an even better Idea?
I had 18 x 10 +12.
Very agressive in the Rota Grid, however id look at Varrstoen wheels next time or some JDM wheels sourced from Japland.
I found they are really shit to drive on with very firm suspension also need to look at other things.
17s in tyres are cheaper and look great on with appropriate ride height width and offset.
I would def look at 17s next time personally, however the 18 x 10 on a gtr looks mint. add in a lil camber to sit more in the guards and it will be dope!!
only issue you might find going wider than a 10 or even with a 10 is rubbing, mine scuffed my inner guards on almost full lock, and gets annoying after awhile in car parks etc.
  • 1 month later...
  • 1 month later...
i just bought some varrstoen 2.2.1 18x10.5 +12 and after seeing this picture im glad i chose those specs looks mint!
Post some pics up in this thread when you've got them on. I was thinking of 18x10.5 +15's but didn't think they'd fit a 32 GT-R so was leaning towards 18x10.5 +22 Varrstoens.
Edited by mambastu
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
