Ok so im running out of space at my place so am selling all the stuff that i have pulled off the gtr since iv had it. this includes all the twinturbo crap, the only things you would need is turbos and water/oil lines, maybe a few nuts and stuff, but all the piping and exhaust stuff is there. pm me if interested.
Also have K's pods to suit gtr, bolts onto the afms. $80
I also have a spare plenum to suit gtr, no throttles or anything, just the plenum. $50
Standard GTR fuel rail. $40
2x Standard fuel regs $20 each
2x GTR Bov's. will only sell as pair. Pm me an offer.
poope you are no fun. i need a bit of stuff as previous owner hacked away at mine to add the atmos ones i have. Car will be going into ultimate tunes soon anyway to get a bit more done so ill take a proper look as to what i need when the front bar is off haha
4 SSR MK1's
Offset: +11 (Type B)
PCD: 4x114.3
Price: $650
Comes with a set of new shank nuts and washers to suit toyota wheel stud thread.
Since I got these I pulled out all the rusted nuts and bolts for the wheel centres and put new ones in.
One rim has a minor dent on the outer lip. Wicked wheels out in qbn should be able to fix it real cheap if you don't want to have a crack your self. If I get it fixed I will be asking a lot more for them.
These are great rims for an old school look and your missus can use them as a mirror to do her make up.
Edited by azathoth
I have some parts lying around forsale
Genuine GTR Door Sills - $250
Please pm if interested
So found out they are for a R34 GTR....
Going to put up on eBay pm if wanting this.
Edited by ScR33m3r
Series 2 R33 Front bar indicator/fog light combination
White lens covers,
Electrics work fine.
Light scratches from moving around on lens covers but easy to sand and paint over.
$180 ono
Pm if any questions or anything
R33 GTR Carbon fibre faced gauge din set.
Brand new been sitting around for a while
$250 ono
Pm any questions or anything
R34 GTR Door scuff Sills
Brand new
Thought they were for a R32 but didn't fit either R32 and R33
$250 ono
Selling helga 96' R33 Skyline GTST - Have advertised on for $4250 with a decent amount of interest. I wouldn't want to go below $3,000 ono. as the car works perfectly fine and drives straight, pits just failed the chassis (among other minor things) - Can be registered in NSW, rego runs out 4th of May 13'. Not sure if I'm asking too much for $3,000 for SAU members but a starting price has been given. Cheers
interested in a 68 hilux?
plus a little cash your way?
needs paint attention, but mechanically very good.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
