Ok so im running out of space at my place so am selling all the stuff that i have pulled off the gtr since iv had it. this includes all the twinturbo crap, the only things you would need is turbos and water/oil lines, maybe a few nuts and stuff, but all the piping and exhaust stuff is there. pm me if interested.
Also have K's pods to suit gtr, bolts onto the afms. $80
I also have a spare plenum to suit gtr, no throttles or anything, just the plenum. $50
Standard GTR fuel rail. $40
2x Standard fuel regs $20 each
2x GTR Bov's. will only sell as pair. Pm me an offer.
poope you are no fun. i need a bit of stuff as previous owner hacked away at mine to add the atmos ones i have. Car will be going into ultimate tunes soon anyway to get a bit more done so ill take a proper look as to what i need when the front bar is off haha
4 SSR MK1's
Offset: +11 (Type B)
PCD: 4x114.3
Price: $650
Comes with a set of new shank nuts and washers to suit toyota wheel stud thread.
Since I got these I pulled out all the rusted nuts and bolts for the wheel centres and put new ones in.
One rim has a minor dent on the outer lip. Wicked wheels out in qbn should be able to fix it real cheap if you don't want to have a crack your self. If I get it fixed I will be asking a lot more for them.
These are great rims for an old school look and your missus can use them as a mirror to do her make up.
Edited by azathoth
I have some parts lying around forsale
Genuine GTR Door Sills - $250
Please pm if interested
So found out they are for a R34 GTR....
Going to put up on eBay pm if wanting this.
Edited by ScR33m3r
Series 2 R33 Front bar indicator/fog light combination
White lens covers,
Electrics work fine.
Light scratches from moving around on lens covers but easy to sand and paint over.
$180 ono
Pm if any questions or anything
R33 GTR Carbon fibre faced gauge din set.
Brand new been sitting around for a while
$250 ono
Pm any questions or anything
R34 GTR Door scuff Sills
Brand new
Thought they were for a R32 but didn't fit either R32 and R33
$250 ono
Selling helga 96' R33 Skyline GTST - Have advertised on for $4250 with a decent amount of interest. I wouldn't want to go below $3,000 ono. as the car works perfectly fine and drives straight, pits just failed the chassis (among other minor things) - Can be registered in NSW, rego runs out 4th of May 13'. Not sure if I'm asking too much for $3,000 for SAU members but a starting price has been given. Cheers
interested in a 68 hilux?
plus a little cash your way?
needs paint attention, but mechanically very good.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
