Fj 20 engine and numerous parts for sale
Engine is in pieces at the moment
Would like to sell whole but will separate
Standard t3
Blow off valve
Standard injectors $50.00 each
550cc injectors $85.00 each no need to drill out injector
Plenum $100
Sump $ 100
Head $ 250
Wisco pistons $50 each
Standard internals
Will sell whole engine $ 500
Will not ship must be picked
For Sale:
Rb26 engine out of r32. 107xxx kms.
new genuine water/oil pumps replaced less than 1500kms ago
new dayco timing kit at same time.
standard everything except nitto throttle body gaskets
comes with all inlet gear except injectors.
Nothing on the exhaust side
will come with sump (no diff in it though)
will come with clutch ( its pretty shagged though)
Lifters are very noisy when motor is cold, goes away once warm. You are welcome to inspect/comp test. motor is still in car and running until saturday.
Pm me
Fs hypergear Atr43g .63 turbo kit comes with turbo high mount manifold 3" exhaust from turbo to cat braided lines and turbo smart external wasit gate $800
I might want it.
For rb 25? 20?
How much use has it had?
Any pics?
Hi guys I'm selling my car audio gear including custom boot set up for an r33 including custom box 12inch clarion sub and clarion amp plus to jl audio splits all top of the line gear if your interested please msg me and i can send pics and other details. 0457133010 cheers
Stripping S2 R33 Parts
Prices are negotiable.
GTST wing $150
ECU $150
Wiring loom $150
Side skirts $150
Rear bar $100
CD player surround $100
Double din CD/DVD player (alpine) $400
Shifter surround $50
Centre console $100
Front seats (minor tear on bolster) $150
Rear seats $100
Boot hatch $100
Tail lights $200
Skyline rear centre garnish $100
Door windows $150 each
Window regs $150 each
Aftermarket cat back exhaust $300
Coilovers $500
Engine $1000 (170,000 kms complete no turbo or bolt ons)
Diff $200
Half shafts $100 each
Rear adjustable camber arms $150
19" rims $1000 with brand new tyres
Turbosmart boost tee $50
Turbosmart boost guage $50
Aftermarket adjustable tie rod ends $100
Stock clutch $100
Flywheel $100
Passenger front guard (perfect condition) $100
Tail shaft $150
Starter motor $150
Alternator $100
Front and rear Brakes $400
Brake rotors $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $100
Front lower control arms $70 each
Seat belts x 4 $150
Door cards $100 each
Window switch elects $100 (drivers side) $75 (passenger side)
Window switch surrounds $100 each
Side mirrors $100 each
Steering surround $50
AC control unit $100
Window wipers $40 each
Fuel flap $75
Fuel cap $20
Bonnet latch $75
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top AC vents $20 each
Passenger side headlight $150
NO FRONT BAR
NO INTERCOOLER or PIPING
NO TURBO
Still left over.
Also have a heap of mint condition I interior parts.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
