R32 Nissan Skyline GTR 1989 imported by me in 2004. $13,500 or reasonable offer.
Complied in the ACT.
I dont get the time to drive it, would like to see it go to a good home.
Located in Canberra but will trailer deliver to you for cost of fuel + hire.
Last rego inspection:
- Back left handbrake was not applying full force.
- One of the engine mounts is split, don't know how long it was like it, never had an issue before, I bought a spare, haven't fitted it.
- Clear is coming off.
Needs a tune, throttle bodies need balancing. I cant afford to get it done.
Steel wheel ball bearing turbos built by Croydon Motorsport, all the under plenum pipes were checked and replaced because the last mechanic overtightened the water bleed screw and it sheared, so when I changed the water pump I couldn't bleed it, had to dismantle the entire inlet side to fix it. Found the paper gaskets blown in two places so put in HKS metal gaskets.
Had the injectors serviced, removed the fuel tank and cleaned the lines out, new fuel lines as well. new timing belt went in a while ago.
Cat back exhaust, HKS Pods, everything else is stock.
My Gloss black GTR Bonnet
Condition is immaculate
has the heat/sound deadener and squirters
$600 (or $700 if you wish to barter)
most have seen it on my GTR or in my mancave
however if you want to drop by or need pics
Just ask
Cheers
Richard
Will also be selling off both sets of my Rays Volk GTC's soon
Gold set to suit GTS-t's (Face 2)
18 x 9 +29 ®
18 x 8 +29 (F)
4 x Federals RSR's on rims Good tread road legal
Minor rash will be fixed first
Sit hella flush on my 34 GTT
$2400
Diamond Black to suit GTR's
18 x 9.5 +15
2 x Bridgestone Potenza's RE050's (road legal tread)
Minor rash is being fixed now
Also sit flush with guards
$2400
Both sets come with Rays Nuts
- Volk CF centre caps
- Socket/s
Payment plans on Rims available if your not so flush with cashish
Interested in those Dimond Black GTCs
Hi All,
I have the following stuff to sell all pickup in Canberra / QBN.
Price is make are offer on here or via PM... My R33 is sold so no longer needed, this stuff will either be ebayed or thrown out
Stock Airbox with high performance filter... good condition
http://imgbox.com/sf**kqx1
Reverse switch (that controls the reverse lights) Brand new genuine nissan.
http://imgbox.com/xqypXZoU
Plastic Box for POD
http://imgbox.com/oFvc0G3k
Clutch and Fan. Clutch is stuffed!!
http://imgbox.com/THybj6ju
RB25det Head... great condition
http://imgbox.com/sKfHLg24
http://imgbox.com/0YnUVuNc
R33 s2 stock exhaust... all the way from dump pipe to back.. good condition
http://imgbox.com/l0c2GHWp
R33 S1 ABS pump... OK condition should work fine though never tested (i had a s2)
http://imgbox.com/eAV1Owii
R33 Stock wheels
http://imgbox.com/vM0IGwzw
http://imgbox.com/WbVGV2uA
R33 Emergency tyre
http://imgbox.com/bmxZHrPT
Hi All,
Plastic Box for POD
R33 Stock wheels
R33 Emergency tyre
And this should be an rb25det block for sale above not head!!
DOWN TO $12,000 - must go.
Also has Greddy Oil Filter relocation Kit.
Just flushed radiator, fitted new battery (SuperCharge batteries are crap), just flushed and put in fresh fuel.
Pretty sure I have fixed the handbrake issue.
Needs a tune. I cant afford to get it done.
Cat back exhaust, HKS Pods, everything else is pretty much stock.
No rust.
Edited by xfixiate
1990 R32 GTR RB26DETT - $22,000 ONO - 0422626173
Up for sale is my 1990 Nissan skyline R32 GTR, It is in great condition with 84,000kms and the original japanese service books, it has been used as an occasional weekend car.
Panasport G7 C5C 3 piece wheels with Federal 595 RSR 255/45/17 (1500kms on tyres)
Greddy Type S Coilovers
Cusco rear camber arms
Cusco castor rods
HKS pod filters
Greddy Cam Gears
HKS Power FC with hand controller
New Nissan injector seal kit with new Pintle caps (installed less than 300kms ago)
HKS electronic boost controller
3.5” catback exhaust with 4” oval rear muffler (nice and quiet)
RDA slotted and dimpled rotors with Intima SR brake pads (installed less than 1000kms ago)
Genuine Nissan Tie Rod ends (installed less than 1000kms ago)
Rebuilt Drive shafts with new CV boots (installed less than 1000kms ago)
Steering Rack boots (installed less than 1000kms ago)
Rebuilt Headlight Switch (installed less than 1000kms ago)
Wheel alignment performed by Capital Steering less than 500kms ago
Edited by JimmyS
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
