  • Replies 49
Odd...? I noticed that the Racepace built GTTRKT RB28 vcam R34 and the Midori R34 both ran external drains to the drivers side sump from washer bottle mounted catch cans.
I suppose if you meant dedicated circuit though, very small restrictors could be used as revs are always up high which would ensure the head gets enough, but not too much oil. Such a restrictor might not be a good idea in a street car though. I believe it was Steve telling me that some of the racepace cars were using a 0.9mm restrictor. Is this what you meant?
Sorry I should clarify - no additional drain @ rear of the head. Factory drains on the cam covers --> catch cans of course. Return to sump or not, plenty of different setups around.
Some users on here have the additional rear drain, restrictors (unsure what size), catch cans and STILL have motors breathing heavily. So something is certainly up when others don't need any additional rear drains to keep things under control.
Dont use a standard sump with a high volume pump. It is a recipe for a blown motor.
+1
Which to me indicated that the rear drains are perhaps not as effective as soem make them out to be. Which is different from saying they are not useful.
So the question then is: What size oil restrictor is in the head of your motor?
From memory I think is was the 0.9 that was in the original build unless he changed it.
I think there was a lot of other factors for the improvement, 5 pounds less boost now runs 20 psi for 355 rwkw, shimed oil pump, standard cams back in that lowered the RPM, better built engine with a much better ring seal and tolerances and a few other little tricks. Just a much better package.
Never had a problem since, not even a drop of oil in the catch can.
There is the main culprit sorted for starters.
So how much tension? How measured on what (brand) rings?
Wiseco pistons and I assume rings so nothing special, more attention on machining getting the block and bores exactly right.
In short, I just spent the dosh and went to someone who had a long history in building and developing RB engines.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
