PLEASE USE EMAIL OR MOBILE TO CONTACT ME. I DON'T CHECK SAU OFTEN. IF YOU WANT A QUICK RESPONSE SMS IS YOUR BEST BET.
THIS IS A COMPLETE LIST. IF IT'S NOT ON HERE I'VE SOLD IT.
PH: 0414795824
EMAIL mojave 15 @ yahoo . com
Car is located in Adelaide SA. Contact me for postage if you need it may have to arrange own courier for bodywork.
Wrecking R32 GTR Good Condition not crashed need to clear the shed. Parts from 2 separate GTR's.
Bodywork I still have:
Doors x4 2 Silver 2 Gunmetal Grey $150 each
Bonnet Gunmetal Grey $400
Boot x2 Gunmetal Grey and Silver $120
LHS Front Guard (Silver) $300
All good condition with glass etc.
Engine
Jim Berry Rebuilt Clutch Almost new under 5000k's easy. $450
Alternator $100
Starter Motor $150 both work fine
Power Steering Pump $80
Brake Master $100
A/C Compressor $120
Plenum semi-polished setup w/throttles etc $350
Plenum Standard setup with throttles $250
Head Works fine removed from running engine inc cams/bolts etc $750
Fuel Rails $40
Window Washer bottle $30
Coolant Overflow $30
Full Brake Setup Front/Rear Calipers + Good Rotors $450
Various Hoses Intercooler etc $30ea
Park Brake $50
Sump/Front Diff $250
Rear Driveshafts $150ea
Fuel Tank $120ea
Gearbox with 33GTR internals $600
Diff $400
Tailshaft $180
R32 Full upgrade fuel setup 550cc Injectors/Rail/Regulator earls fittings $450
Unused Catch can $30
Window Wiper motor $40
Crank Pulley $80
R32 Stock Pistons $150 per set (2 Sets of 6)
Standard GTR Injector's 4 Only $50 ea
Steering Rack $200
Interior
Glovebox $30
Door Card $80
Wiring Looms Various $200 ea negotiable
Extreme TSC 4WD Controller Custom Box $120
320kph Cluster $250
Wheels
4x Advan 17" x 9 with good tyres $750
2x R34 Gtst Rims Stock Good Tyres $200
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
