hi guys thanks for the help
ive got an r33 and i want to make 300+rwkw, what can you suggest for me to do that i havnt done..
ive got...
dual roler baring high flow turbo (run 18psi)
nismo fuel pump
550cc injectors
microtech ltx12
blitz return flow FMIC
full 3 inch stainless steel exhaust
tomie cams + cam gears
will spiltfire coils do anything?
i havnt got it tuned yet but its booked in start of june..
thanks for the help
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/
coils won't get you any more power mate. only if your old ones are breaking down.
you'll struggle to make anymore than 350hp on a highflow turbo. you'd need something like a gt3071r or a hypergear atr43tggathkj. thingy. if you run any more boost than 18 you'll be out of the efficiency range of the turbs.
but looks like youve got most of the basic supporting mod!
+1 for big clutch.
ps keep in mind 400hp is getting close to the limit of the stock engine!
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6368849
thanks people and i forgot i have a exedy heavy duty cushion button..any other mods i havnt done?
well you've only just scratched the surface and the mods you've listed are practically bare minimal requirements...
and as others have said you wont make your goal power figure with your list of parts...
I guess we could start listing suspension, brakes and cooling mods to make it so the power can be used and controlled, but Im sure youve already done that yeah, right, yep done that uhuh...
whats with this magical 300 number anways...?
why do you want 300?
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369160
Check out the hypergear thread if you want to keep the stock manifold and dump. Check out the kando thread if you dont. I vouch for the hypergear atr43g3, with those cams, you should see 300rwkw. You can install it yourself if you're confident enough and have some tools. I hear lots of stories about those return flow coolers overheating, not sure about the blitz ones.
https://www.sau.com.au/forums/topic/400916-rb25-kw-help/#findComment-6369354
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
