Hey guys,
Ive just finished the painful process of extracting exhaust manifold studs, now apon inspection of my turbo (stock) I have noticed that the swing valve is loose?
Sorry Im not all that clued on with turbos but I am assuming that should be shut pretty tightly?
If it is supposed to be closed tight is there a way to adjust it? Not sure how it all works.
Btw the actuator rod is tight, just the circular swing valve is flappy :/
Cheers
Edit: a bit mor info, the reason for doing the studs was exhaust leak (duh) now, one of the symptoms I was experiencing was a flucuation in boost. Almost like a flicker as it was climing. Now I just assumed that was part of the leaking manifold but now... Could this be caused by this?
Edited by GoHard
https://www.sau.com.au/forums/topic/401007-swing-valve-resting-position/
A picture? I was trying to think how I could take a picture of movement...
I guess this might explain it? Should I be able to slide a piece of paper behind it when closed?
Its loose enough to spin freely with my finger. I hope this helps?
there should be some adjustment on the actuation rod that it's connected to it. adjust the rod so that flap is hard up against the seat. it'd be worth cleaning all the carbon off around the seat before adjustment.
cheers
justin
to me it sounds like there is more wrong with it than just the need for adjustment.
I dont think he should be able to freely move the wastegate with his fingers... or is it just the valve/disc that covers the hole that has some freeplay but the overall mechanism is still stiff and cannot be moved by hand?
Yeah mate the whole assembly is stiff as. Its just that circular disk that sits a bit loose.
See in the pic, i can grab onto the shaft (dead centre of disc) and it feels like very minute shaft play. I can spin it from there.
put some washers between the turbo and the bracket the actuator is on... :whistling:
What I really need is a washer on the swing valve to shim it, but there is no way of taking it apart to get a washer in there. Circlip maybe but thats worth even more :whistling:'s
This, should solve your problem nicely. Put enough washers on there to hold it shut and then an extra 2-3mm, should raise your boost a touch.
Justin, johnathon... Thank you. Thank you so much. A washer under the bracket of both bolts brings it closed perfectly!
Is this safe? There isn't much surface area for the bracket to sit on in the first place so I dont see why not. This has been done before?
Edited by GoHard
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
