IM PARTING OUT MY 1994 R32 GTR , CLUSTER SHOWS 62000KMS
MOTOR HAS BEEN SOLD
Apexi power intake pipes with apexi filters and z32's with plugs $450
Gearbox pull type being 94 model $600ono
Hks oil filter relocater and oil cooler all hoses $450
Rear diff and half shafts $500
Front bar reinforcement $120
Seats front and rear the front seats need retrim but besides that all good with rails $400
Alternator $100 , Starter motor $80 Ac compressor $80 , power steer pump $80
Bootlid with wing in white has a dent or two nothing major $150 ono
Front and rear calipers and discs and braided lines $550 ono
Front cv shafts $200 for both ono
rear tail shaft $120 ono
front pipes 2.5 inch to 3 inch at cat slight scratches from speed bumps $80
3.5 inch cat back one muffler and cannon great sound $450 ono
Heaps still left pm for prices and availability
IN SYDNEY WESTERN SUBURBS PICK UP ONLY
PRICES MAYBE NEGOTIABLE - NO LOW BALLERS PLEASE
Forgot still have front and rear subframes
Hubs abs sensors tail lights
Master cylinder and booster
Clutch master and booster
Abs module fuel tank
Pm for info
Front reo sold, front bar sold , guards sold
Headlights sold , engine sold , grill sold ,
Wheels sold
Inter cooler that's up has some bent fins and some bugs but no leaks 4 inch thick 150 pick up
If your chasing something do your 32 pm me
Also has adjustable coilovers
Will have brand and pics up by tomorrow
Interested in the coil overs if you can let us know what brand, specs etc.
Coil overs sold , fuel sender sold
Fuel pump still available 50 bucks
Fuel tank 80 bucks with straps
Full brake set 450 Calipers discs front and rear
Brake master cylinder and booster 150
Clutch master cylinder booster and hydraulic pipes 150
Abs module 100 bucks
Rhf plastic guard liner complete 50 bucks
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
