Hey mate I have a 1996 N/A manual GTS-4 R33 for sale for about $10k.
140ks on the clock, in good nick and clean as a whistle. Comes with reg and will get roadworthy when it's sold.
Where are you located? Car is in Melbourne, VIC.
Pics at http://imgur.com/a/UaGGR (exhaust in pics is fitted to comply RW but will come with nice and loud dual 2.5inch-tip custom-made cat-back exhaust system).
Pm me if interested.
Edited by d4l337
If you can wait until August (when I get back from Japan) I'll be selling my 1993 R33 GTS for $6K
210,000km on the clock, Manual.
Just had it's 200K service at the start of the year (timing belt, flushed all fluids, replaced water pump and other odds and ends)
Hasn't been driven since March.
The car is basically stock aside from BBS wheels and Bosch fuel pump.
Gonna get a fresh set of tyres when I get back to Aus for RWC (included) and will be rego'd until September 2012 or March 2013.
Only downside is a scuff and crack on front bumper (driver's side, smaller than the size of an A4 page) from someone swiping me, but the rest of the car is pretty tidy inside and out.
Car is in Melbourne's inner suburbs
Don't have many pics cuz I'm overseas, but I can take more when I get back. I'll be back first week of August.
http://i1219.photobu...0x/IMAG0364.jpg
http://i1219.photobu...0x/P6170887.jpg
Edited by grey_fox
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
