Hey guys, i recently bought a GTS-T to get the manual conversion out of for my VL, so the rest is up for grabs!
Car is white.
The main thing i want to advertise is the engine, 120,xxx km on it (i'll double check later in the week)
series 2 with all bolt ons etc, engine is still in car and runs (without AFM though), i can put a vid up of the engine running as well. Asking $1500 with loom and computer. If i get what i'm asking might be able to throw in some other stuff off the car if you need it.
Apart from that the rest i have no idea what its worth, feel free to post and ask for certain parts, will post to wherever as long as you are prepared to pay.
For the sake of it i'll put up a list of things the car doesnt have:
-Some interior parts i already sold to a few mates
-Gearbox/Flywheel/sandwich plate/starter motor (BUT the standard clutch is available)
-Front Bonnet, guards, spoiler (damaged)
-Passenger door
I think thats it, cheers for looking, pics to follow.
Edited by xAsh-
Also i forgot to stick up my number its 0434925964
Damage is on front drivers side, stat write off as the damage was too close to the strut tower to re-register, the actual suspension itself is intact however.
Not keen on tearing up the subframe/brakes etc until the engine is gone, need it rolling until then.
Prices (note: prices borrowed from another users ad)
Tail shaft $200
Rear subframe $120
Diff center $200
Driveshafts $65 each
HICAS $80
Power steering rack $150
Power steering bottle $20
Brake master cylinder $150
Sway bars $20 EACH
Horn $20
Front wiper motor - $50
Rear Wiper Motor - $50
Steering column $50
(Body parts)
Drivers door $220 (slight mark on it, missing window switches on inside)
Boot $200 with what i'm told is a series 2 wing
Rear tail lights $80 each or both for $140
(DASH PARTS)
turbo cluster with 120,000km's $150
Dash good condition $250
Glove box $30
Center console missing manual shifter insert $100
Heater core $70
Aircon core $70
Heater fan $20
(INTERIOR)
Indicator/wiper switch assembly $100
Handbrake lever $30
Rear trims $30 each or both for $50
Seat belts set of 4 $150
Carpet fairly good condition $50
Roof lining $40
Skyline Skuff plates, both sides $35
Rear Seat - $100
Door seals $25 each
Boot seal $25
Rear ¼ trims - $50 each
Rear1/4 window surrounds $50 each
A pillar Trims $20 each
B pillar trims $20
Rear Vision Mirror $20
(ODDS AND ENDS)
Fuel tank $30
Fuel pump $50
Quarter glass if i can get it out intact lol $30
Rear window (as above) $200
Battery holder $20
Wipers $15
Fuel lines $50
Fuel flap $10
Fuel cap $10
Engine Mounts - $80
Radiator overflow bottle (cant remember if damaged)- $20
Sun visors $30
Handbrake assembly & cables - $160
Hey Ash,
Do you have the wiper amplifier/timer? It's a brown box bolted down on the drivers side behind the strut tower. Controls intermittent wipers.
Yeah i'm sure i've got that, where bouts you located?
Hey mate I'm after a rear sway bar and linkages, any chance you could freight it to albury nsw?
Hey mate i probably wont have the chance to get anything off the rear end until after i get back from overseas, i'll send you a message when i get back and see if you are still after it, cheers
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
