Does anyone know if there is a Nissan interchangeable lid for S2 C34s?
I was looking at the snorkel part that feeds over the rad support and it would be nice if it were bigger I guess.
Also as a seperate idea I was thinking of holesawing the lid of the airbox behind the healdight (only the lid obviously so I dont bypass the filter).
Anyone done this with any results.
My overall goal is to have my engine bay always look stock (for the popo) but would like to remove intake restrictions.
I know that the intake pipe can suck shut as flow increases also, so would like to swap for something smoother and stiffer whilst keeping factory looks.
http://www.ebay.com.au/itm/SILICON-INTAKE-PIPE-4-SKYLINE-R33-GTST-R34-GTT-STAGEA-/170841624520?pt=AU_Car_Parts_Accessories&hash=item27c6f44fc8
The link above seems legit and says it matches R34 NEO but not 99 onwards C34s?
Is the ebay seller just unsure of the models?
It's quite hilarious to see them put metal rings on the outside to prevent ballooning on a pipe that only has vacuum!!! As scott said - get an aluminium one.
In terms of the airbox, there is such small gains to be had in this area, that the factory job is a-ok. Sure you can put a hole in it.... then what ?? hot air from engine bay ? route a flexi hose to ? get water in ?
I never had the factory airbox (car came with pod) so i made up my own heatshield and front air duct larger than the standard ones. Tests have proven very little in terms of positive gains when mucking around with airboxes.
This is what i did - http://www.skylinesaustralia.com/forums/topic/348629-what-have-you-done-to-your-stagea-lately/page__st__4200
The turbo's gonna heat it up anyway, so possibly focusing on better intercooler temps ( better ducting, removing some inner guard plastics, fans/sprays ?, upgrade ) and also better underbonnet temps ( remove heat shields, partial rear bonnet seal, bonnet spacers ).
Those ones suck closed quicker than the stock rubber one. Silicone gets very pliable when hot. You need an alloy one. :whistling:
Glad i asked about the silcon intake, thanks, I couldnt see why the metal rings were there either.
I will probably do the 'put a short piece of ally pipe down the centre section of the stock pipe' instead thats in the DIY thing.
As for the airbox holes, I was kinda hoping for a little more induction noise without going backwards regarding hot air or water inlets.
Ill probs just leave it....
Forget I said anything.
The rings aren't there to stop ballooning but they are there to keep the pipe from flattening out under vacuum.
When I had my RB25DET I used the stock airbox and snorkel and made a hole in the top of the airbox and ran a duct to behind the headlight (plenty of air gets through there). Didn't really get to test it as I broke a few ringlands and had to pull the engine but its fairly easy and cheap to do - why not give it a go?
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
