Hey all, new to skyline australia and figured best place to ask the questions.
I currently am on my P-plates in Queensland and own a 1993 R32 GTS 2door. I bought the car off a mate and comes with an untouched rb20de showing around 160,000kms. Only mods done to the car are genuine sparco deep dish steering wheel, tein hr coilovers, advanti 17x8.5 wheels, exedy heavy duty clutch, solid rear cradle bushes, locker, pig pipes and stripped interior. The car has already seen a couple of track days at QR aswell as many industrials :).
However I am only on my P's for another 9months and am looking at my future options with the car. I am planning on further modifying the cars cosmetics (kit, new wheels, roof spoiler) and modifying the handling and suspension (adjustable arms, strut bars etc.) for the remaining 9 months as these are the only modifications as I am allowed to do.
Engine wise I am wanting to replace the rb20de with a rb26det (single turbo). What I am asking is if anyone has done this conversion from a non-turbo gts before or whether I am wasting my time and should just look into selling as I go on my open license.
I understand the hassles with converting to the 26 such as gearbox from awd to rwd and the adjustment to the sump and wiring etc.
Any advice or assistance would be great, look forward to hearing everyones thoughts and opinions.
Cheers,
Sell the car to another p plater as non turbo cars go for more $ than the turbo cars and save your money from the engine conversion, ($4k+) and the sold car, ($4-6k). That would roughly get you $10k+ together, then just buy a r32gtr with some added cash.
They can be had pretty cheap these days. 14-15k for a decent one. Then build up from there.
Fair point, How difficult is it getting the GTR to RWD? I know you can remove a fuse i believe? but is there more to it than that? also is it worth still doing the handling and cosmetic mods to the N/A and then just changing over to the new car when i get it, or are most parts between the gts and gtr incompatible?
if you simply want rwd (i'm guessing you want to do skids, otherwise you'd be silly to want to run the gtr as rwd), then simply sell your car and buy a gts-t, then spend the extra money doing mods. don't bother with putting a rb26 in, because for much less money you could put in a rb25 and do mods to be putting out much more power than a rb26 for the same budget.
or buy a gtr as said above.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
