I had a battery on charge in the garage that got tipped over. I didn't realize it immediately :( but i was on it's side for no less than an hour. It's an Exide sealed battery, you know those yellow top ones you see in K-Mart. Now the battery is good, but it got low due to alot of cranking. So I figured it would be good to give it a nice trickle charge.
I don't want to cause any damage to this battery by doing the wrong thing. So am asking advice on how to check the water levels, and if I should put in some Inox Battery Conditioner as well?
Should I get one of those glass tube things with the rubber ball on the end to test the avid levels too?
https://www.sau.com.au/forums/topic/401808-battery-tipped-and-spilt-some-acid/
If you can open the top you can put some distilled water in an charge it up.but don't fill it right up. Usually about an inch from the top. You don't need a hydrometer to check it. If you can't open it how much leaked out?
It didn't seem like alot leaked out. Not sure on the measurement, but at least a couple of tablespoons full. The smell was quite strong when I cleaned it up.
Is there a more precise measurement to fill it up to, or just go an inch from the top?
I'm just reading on the Exide website how my battery is supposed to be spill resistant. Hmm time to give them a call I think. Maybe somethings wrong with the battery. Granted it should have ever been on its side, but it's fairly new and supposed to be a decent one.
Ah it's not a sealed battery. All batteries will have a breather so don't stress. When you remove the caps the plastic below the threads goes down about another inch. Fill till it just reaches the plastic.
Water or add soap if you really wanna get bling on it. I would just put the hose on it
Have never used that stuff. Adding distilled water then charging will turn it into acid. Cheap n easy
Just read product statement and it's designed for rarely used batteries to prevent them dying from sitting stagnant.
Edited by t_revz
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
