well its snowing heavily here in the south island Nz today, so on my way home i push the button SNOW and the car went from 2wd to 4wd.
It works brilliantly it starts in 2nd gear and i think its 40/60 split torque. Also the heater under the windscreen works a treat, no snow build-ups. ;)
https://www.sau.com.au/forums/topic/401890-snow/
Thats something not many of us are able to try out!
I think its a 50/50 split, and the other thing I notice is that the Throttle map is heavily reduced, giving you that sluggish feeling. I guess gearbox pressures are reduced too.
I only use it to get the car up onto ramps easily!
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6386472
Yep, snow mode is fantastic - does exactly what its meant to! I took mine from Adelaide to Falls Creek 2 years ago now I guess and the car was absolutely brilliant, didnt miss a beat. Defrosting the windows and mirrors was also a nice added bonus of my cold weather pack :D
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6386489
i don't have a torque meter or anything to find out so what happens when i press the snow button in my manual converted rs4?? does it just do the torque and forget about using 2nd? or does taking out the auto box mean i am just turning on the light in the dash when i push the button??
https://www.sau.com.au/forums/topic/401890-snow/#findComment-6390021
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
