Hi guys.
I'm looking to buy some Dzus fasteners to fix panels, under trays and diffusers etc to my car for quick removal.
Can anyone recommend where to buy from? Seem expensive in some places. Tried eBay too. but unclear on how they attach to the fixed part.
I want the self ejecting type on this website.
http://www.performancewholesale.com.au/component/content/article/305-dzus-part-numbers?catid=57#selfeject
I'm a bit unclear on how they attach to the fixed part. Any advice or guidance.
thanks
Russ
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/
these things can be a bit of a pain, especially for things which are on and off regularly. They can get sloppy and misaligned.
There are other types of clips, or even consider bonnet pins for ease of use
I completely agree......
If you're looking at these for undertrays or flat floor sections I'd consider again Russ.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6387914
These are awesome for certain things, such as bodywork etc that comes on and off fairly often. Definitely wouldn't use them on parts that are excessively heavy or may take a hit, like a floor or undertray though.
Major negative in my opinion is that they aren't very tolerant of misalignment. If you want them to much locating of the part, there are better options.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6392660
  • 4 weeks later...
All of the turbine helicopters use these for most of the exterior panels that aren't structural. You can buy the in some fairly large sizes and I haven't ever seen any fail that haven't been miss installed (wrong length or old/over tightened and broke the tangs).
If it has to take load I'd run nut plates and countersunk screws with a reinforced section in the removable panel. Might take 20 seconds longer for 6-10 screws to remove but for piece of mind. Buy an electric screwdriver and its the same time.
Also note that nutplates are way stronger than rivnuts without the issues as there steel not aluminium.
A few places on the airport sell dzus fittings in different sizes and styles.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6431335
Could try Camlocks too, often used in aviation where the breeze would be something approaching LMP speed on the Mulsanne.
Pretty much all methods mentioned, require reasonably accurate hole location.....although you can get floating nut plates that give extra wiggle room. Wicks and Aircraft Spruce - among others, do have handy little duplicating devices and templates which can save a bit of potty mouth during the fabrication.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6433880
  • 1 month later...
Dzus Fasteners? I work with them everyday. they are okay when new but after a bit of use.... they are designed to save time and to make sure stuff isnt overtorqued but after a bit of use they are just dumb. usually-well mannered people start using swear words and even invent some, and to be honest, they are pricey. Use the money on a good snap-on electric screwdriver, get some anchor nuts (nylock type) and forget these stupid things.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6505819
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
