Hi guys.
I'm looking to buy some Dzus fasteners to fix panels, under trays and diffusers etc to my car for quick removal.
Can anyone recommend where to buy from? Seem expensive in some places. Tried eBay too. but unclear on how they attach to the fixed part.
I want the self ejecting type on this website.
http://www.performancewholesale.com.au/component/content/article/305-dzus-part-numbers?catid=57#selfeject
I'm a bit unclear on how they attach to the fixed part. Any advice or guidance.
thanks
Russ
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/
these things can be a bit of a pain, especially for things which are on and off regularly. They can get sloppy and misaligned.
There are other types of clips, or even consider bonnet pins for ease of use
I completely agree......
If you're looking at these for undertrays or flat floor sections I'd consider again Russ.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6387914
These are awesome for certain things, such as bodywork etc that comes on and off fairly often. Definitely wouldn't use them on parts that are excessively heavy or may take a hit, like a floor or undertray though.
Major negative in my opinion is that they aren't very tolerant of misalignment. If you want them to much locating of the part, there are better options.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6392660
  • 4 weeks later...
All of the turbine helicopters use these for most of the exterior panels that aren't structural. You can buy the in some fairly large sizes and I haven't ever seen any fail that haven't been miss installed (wrong length or old/over tightened and broke the tangs).
If it has to take load I'd run nut plates and countersunk screws with a reinforced section in the removable panel. Might take 20 seconds longer for 6-10 screws to remove but for piece of mind. Buy an electric screwdriver and its the same time.
Also note that nutplates are way stronger than rivnuts without the issues as there steel not aluminium.
A few places on the airport sell dzus fittings in different sizes and styles.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6431335
Could try Camlocks too, often used in aviation where the breeze would be something approaching LMP speed on the Mulsanne.
Pretty much all methods mentioned, require reasonably accurate hole location.....although you can get floating nut plates that give extra wiggle room. Wicks and Aircraft Spruce - among others, do have handy little duplicating devices and templates which can save a bit of potty mouth during the fabrication.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6433880
  • 1 month later...
Dzus Fasteners? I work with them everyday. they are okay when new but after a bit of use.... they are designed to save time and to make sure stuff isnt overtorqued but after a bit of use they are just dumb. usually-well mannered people start using swear words and even invent some, and to be honest, they are pricey. Use the money on a good snap-on electric screwdriver, get some anchor nuts (nylock type) and forget these stupid things.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6505819
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
