Eoi:- Private Drag Day At Adelaide 1/4 Mile. July 1St 2012
  • Replies 197
Posted Images
Jap_Star the WR600 indicates a final power output figure of 600kw or 800hp crankshaft power potential from the package. Currently it makes 460kw or 620hp at all four wheels on track rubber, so we are getting close :)
hey mardy wanna see some of the 35 u going to be there all day sunday weather permitting?
and that 60 needs some love :whistling: . one of the boys did a 1.47 60ft with a non stalled zf no gears either 2wd lol :wub:
A decent wire to the alternator might be worth a try then matt, only cost a few bucks. what turbo you using atm?
What powers the r35 gtr make to run in the low 10s?
Andrew
I'll certainly look at it as an option mate, makes perfect sense.
Current turbo is a custom Turbonetics T62-1, had it for a few years now. It will produce approximately 625-650HP.
Nice matt, Are you running tomorow?
Is the day still going ahead? chance of rain i heard.
Fingers crossed the rain holds off or doesn't pass through the area. I'm planning on running, weather is the main deciding factor. Please, please don't rain! I've been waiting 6 years for this!!!
so i got some vids of a white r32,burgandy33 and a black 33 and munro and willal's 35 ( what happened marty ) if u want ill post some up if u dont want also say and i wont up load them to u tube
Have updated my signature!
Is it possible to edit out the rego plates if going on youtube?
One run I did a prelaunch & put it into limp mode. Held it flat but
would only let me do a 19 sec pass - man it felt like forever!
The other 4 runs we good though, pretty happy with that.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
