Hi Everyone im brand new to Skylines AUS and if there has been a thread made up for this topic already please redirect me and delete.
Anyways im really wondering if there is any possible way that the Nissan Skyline R34 GTR Performance parts can be fitted onto the Nissan Skyline R34 GT-T.
e.g
(Engine)
-Turbo kits
(Exhaust)
-Catalyctic Converters
-Dump Pipes
-Front pipes
-Headers and manifolds
-Mufflers
-Straight pipes
(Engine Continued)...
-Belts and Pulleys
-Bolts and Bearings
-Camshafts
-Connecting Rods
-Crankshafts
-Earthing kits
-Fittings
-Forged pistons
-Fuel Systems
-Gaskets
-Ignition
-Injectors
-Mounts and Dampers
-Oil Parts
-Plug leads
-Spark Plugs
-Stroker Kits
-Valve train
(Drive Train)
-Bushes and Mounts
-Differentials
-Fly Wheels
-Gear sets
-Shift kits
(Intake)
-Ducting
-Induction Boxes
-Panel filters
-Piping
-Pod Filters
-Surge Tanks
-Throttle systems
(Aerodynamics)
Any help on finding out wether i can put an R34 GTR Bodykit or type bodykit on it would be useful if not the appropriate steps to obtaining an amazing body kit for the car prefferably something that is wide at the wheel wells and sharp and sleek on sides and front.
Im hugely greatful in advance for any helpuf information regarding my Post im not sure wether this has benn asked before but as im new i dont know again huge thanks to anyone that can point me in the right direction thankyou very muchly.
e.g
(Engine)
-Turbo kits
Can be done, but definitely not worth it.
(Exhaust)
Again, probably can but there's no point.
-Dump Pipes
No
-Front pipes
No
No
-Mufflers
Yes but not worth it.
-Straight pipes
Yes, might require a bit of modification. Again probably not worth it.
-Belts and Pulleys
-Bolts and Bearings
-Camshafts
-Connecting Rods
25 Neo already has the same con rods.
-Crankshafts
-Earthing kits
Eh? I imagine so as these are just wires, but lengths may differ.
-Fittings
What fittings?
-Forged pistons
No, Neo head requires special dome top pistons.
-Fuel Systems
Fuel pump yes, but beware of buying second-hand fuel pumps.
-Gaskets
Some maybe, most no.
-Ignition
No.
-Injectors
No.
-Mounts and Dampers
-Oil Parts
Like?
-Plug leads
RB engines are coil on plug.
-Spark Plugs
-Stroker Kits
-Valve train
Most of it is the same anyway.
(Drive Train)
-Bushes and Mounts
-Differentials
-Fly Wheels
-Gear sets
-Shift kits
(Intake)
-Ducting
-Induction Boxes
-Panel filters
-Piping
-Pod Filters
-Surge Tanks
-Throttle systems
Yes, with lots of messing around.
(Aerodynamics)
Can be done. Expensive.
Have answered the ones I know, but most of what you have asked is completely pointless. The RB25DET Neo engine is a very good motor, there's no point trying to put RB26 stuff in it. You want a GTR then buy a GTR, it will be cheaper and better than converting a GTT to one. You've got a GTT. Build a GTT.
Prob end up with a massive hole in your fuel map and unload in 3rd
Told you it was 3rd!!! :rofl2:
But on a serious note, the 34GTT is a great car to build, it is also an expensive car to build as most parts out there say "suits 32,33 & 34GTR", the ECU's and injector options etc were a tricky one for a while, it seems as they are becoming more frequeuntly modified parts are becoming more readily available..... But as JustinP says, read read read...... Awesome forum with heaps of info to offer :w00t:
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
