Nah staying in Goulburn tonight :)
Should get there around 6
Hmm forcastvfor Friday 10-20mm of rain. Is that enough to leave the track wet all day?
I saw another western stie. Were getting 1mm at 6, 9, 12, 3 dunno if 1mm will affect us much?
haha excellent. we got her a car harness, do you have yours in the front seat or in the back?? i know its illegal but i think id like her in the front just so i can keep an eye on her.
Roxy rides shotty in the front with me. :action-smiley-069:
had my -7s installed, still no farking boost, took it to Jez, stuck it up on the Dyno and it runs 1 bar 255k at the wheels, take it down put it on the street, does 1 pull then goes flat, He changed the timing as it was pinging off its head, Team K played with the timing looks like its off, so that got sorted on the dyno and then it went flat had 26 degrese on the dyno and was safe, then on the street it cut in half like it went into safe mode or some shit, more investigation will happen with Jez tomorrow, plugs, coil packs and ECU getting looked at.
How exciting Owen!
K I S S I N G!!!
Nats was so fun!!!!!!
Brothers best time was 1:15.00 mine was 1:16.40 :( bastard!!!
Oh... I do have bragging rights over Mr 360kw ;)
He said he had fuel issues but I know it's all an excuse ;);););););););!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
