just had a thought, it would be easier for you to come over here with your one car and cruise with us, than for us to come with our many cars....
where's your sense of adventure? it's only ~3500kms...call it SAU's biggest cruise. :woot:
Plus my car already was over on your side..i'm even still rocking with nsw number plates. :yes:
The guys for the SAU Nationals did it! So you have no excuse :P
funniest shit today, i call it... using a sv6 as a work ute, FAIL!
weve had construction on our rail tracks out the back and they keep driving there work vehicles over the tracks so there tools are closer, today they had a big dumper thing in to rip out all the dirt around a stretch of rail and fill it with ballast (basically rocks the size of your fist) so its stronger when locos go past.
so come 315 when the construction team is getting ready to go home and an sv6 drives over the rail when we got locos coming and the big dumper thing still right in front of him. scraps his front bar on the rail, and balast. then gets 1 rear wheel over the rail and 1 wheel outside the rail like on a diagonal, he then gets stuck in the middle of the tracks and starts single pegging on the ballast and cant move hahahaha f**kin holdens.
we got the idiot out :P
Sucks to be him
But doesn't matter what car it is they are all the same
Was doing a delivery at Woy Woy today and had to back in the driveway at the store as you do but because the pack of sheets was right at the back I had to stop short and block the entry/exit so they could get it with the forklift as there is a drain a bit further back.
the crappy forklift the store uses would get stuck on the drain if I backed the truck right in
I exit truck undo straps drop gates ready for the forklift when this muppet in a beat up Falcon ute basically parks on the footpath in front of the truck then gets the shits cause the truck is in the way
Could have easily parked next door but for some reason he leaves the ute on the footpath and blocks everyone
f**kin idiot
have dropped the price to 16500 and theres still f**k all interest, have it on ebay and have got a few people asking what the reserve is and as soon as they hear it they dont write back, have gotten an offer of a v8 statesman hahaha.
whats going on ay, its like the 6th cheapest on carsales.
car scene is DEAD!!!!
theres 5.5 days left on the ebay add with 40 watchers so hopefully someone has more then 8 grand.
hahaha yeah i wouldnt sell yours either, lots more blood sweat and tears in yours!
...maybe not tears, im a bitch. hahahahahahahah
not even getting low ballers so i thinks theres just f**k all buyers. everyone is way to responsible now days, drove to rajs corner and got so many looks in the 5 mins, take off those collars ya whipped bastards.
maybe i should put sticker on car...
Sucks to be him
f**kin idiot
The best way to deal with the 3 head retards in woywoy is to hit them till the stop moving then kill them with fire. ur doing the world a favor by doing this also
True
Yesterday I'm down there and twice I had p platers try and drive around the truck while I'm reversing into stores
How hard is it to wait 30 secs and let a big f**k off truck get out of the way instead of risking a lot of damage to your car
whos organising the next cruise and where to? its either martin or chookies turn to organise, unless someone else would like to have a turn and choose a route theyd like to show everyone?
u may have to stay home for the next cruise if u sell ur car mate.is anyone from newy goin to the top secret car meet at eastern creek on friday night?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
